13
So I have an Alienware 13 R3 with the OLED display, and for the first time I was able to change the brightness using the xrandr command. The problem was the absence of backlight in OLED displays, so I couldn't change the brightness wither with the keyboard, or in any other way. So now that I know I can change it, I want to put a key binding to change the brightness by let's say 0.1. I used this command to change the brightness:
xrandr --output eDP-1-1 --brightness .5
Does anyone know what command to use not to set the brightness, but to increase or decrease it by some value, so I can bind a macro to it. Thanks in advance!
P.S. I am completely new to Linux, so please don't go hard on me :P
Fjolfrin
  • 133
Copy bash script below to a file called bright
Then mark it executable with chmod a+x bright
Bash Script
#!/bin/bash
MON="DP-1-1" # Discover monitor name with: xrandr | grep " connected" STEP=5 # Step Up/Down brightnes by: 5 = ".05", 10 = ".10", etc.
CurrBright=$( xrandr --verbose --current | grep ^"$MON" -A5 | tail -n1 ) CurrBright="${CurrBright##* }" # Get brightness level with decimal place
Left=${CurrBright%%"."} # Extract left of decimal point Right=${CurrBright#"."} # Extract right of decimal point
MathBright="0" [[ "$Left" != 0 && "$STEP" -lt 10 ]] && STEP=10 # > 1.0, only .1 works [[ "$Left" != 0 ]] && MathBright="$Left"00 # 1.0 becomes "100" [[ "${#Right}" -eq 1 ]] && Right="$Right"0 # 0.5 becomes "50" MathBright=$(( MathBright + Right ))
[[ "$1" == "Up" || "$1" == "+" ]] && MathBright=$(( MathBright + STEP )) [[ "$1" == "Down" || "$1" == "-" ]] && MathBright=$(( MathBright - STEP )) [[ "${MathBright:0:1}" == "-" ]] && MathBright=0 # Negative not allowed [[ "$MathBright" -gt 999 ]] && MathBright=999 # Can't go over 9.99
if [[ "${#MathBright}" -eq 3 ]] ; then MathBright="$MathBright"000 # Pad with lots of zeros CurrBright="${MathBright:0:1}.${MathBright:1:2}" else MathBright="$MathBright"000 # Pad with lots of zeros CurrBright=".${MathBright:0:2}" fi
xrandr --output "$MON" --brightness "$CurrBright" # Set new brightness
Display current brightness
printf "Monitor $MON " echo $( xrandr --verbose --current | grep ^"$MON" -A5 | tail -n1 )
  • Change MON="DP-1-1" to your monitor name, ie MON="HDMI-1"
  • Discover your monitor names using xrandr | grep " connected"
  • Change STEP=5 to your step value, eg STEP=2 is less noticeable
Call the script with:
  • bright Up or bright + to increase brightness by step value
  • bright Down or bright - to decrease brightness by step value
  • bright (with no parameters) to get the current brightness level
Hopefully the bash / shell commands can easily be googled for education but if any questions don't hesitate to ask :)
8 minutes after posting answer it occurred to me I could have used bc for floating point math and saved ~10 lines of code and the a lot of time from the 1.5 hours to write it shrugs.
