I recently upgraded my Google Cr-48 to Ubuntu 11.10 from Ubuntu 11.04. It appears as if there is something behind the title bar. Is this normal?
I also need to ask how I can take a screenshot to show this. I don't have a Print Screen key.
Jorge Castro
  • 73,717
For a screen shot type "Screenshot" into the search bar. (Its the one with a camera ;) )
It's possible you are seeing some of Gnome panel (but without seeing I cannot say for sure.) This is because gnome panel runs underneath unity panel! So if you set the opacity of unity to 0, you'd be able to see gnome. Weird eh!
BrownE
  • 805
you can reassign the screenshot shortcut in system settings under keyboard->shortcuts-> screenshot
It might be the Nautilus menu bar. When running in Classic mode with Nautilus on the desktop a Nautilus menu bar would be hidden behind the top panel, moving the panel out of the way would reveal it. So while it might be 'normal' it's certainly a bug.
Grumbel
  • 4,879
@BrianH If you use the SD card slot as a extra disk you will have extra space.
For example, chromedisk is a 16 Gig SD card
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/sda7             10321208   3940068   5856916  41% /
devtmpfs                969872       528    969344   1% /dev
none                    970092       536    969556   1% /dev/shm
none                    970092       168    969924   1% /var/run
none                    970092         0    970092   0% /var/lock
/dev/sdb1             15313808   2033372  12502536  14% /media/chromedisk
Ralph
