ok, this question may seem retarded as there has been so many documentation on this: Installing CodeLite on Ubuntu 14.04LTS (Trusty Tahr).
I followed exactly the steps in: http://codelite.org/LiteEditor/Repositories with special caution to getting the repository right as emphasized in: http:// forums.codelite.org/viewtopic.php?f=3&t=2914&p=13302&hilit=trusty+install#p13302
sudo apt-get purge codelite codelite-plugins
sudo apt-key adv --fetch-keys http://repos.codelite.org/CodeLite.asc
sudo apt-add-repository 'deb http://repos.codelite.org/ubuntu/ trusty universe'
sudo apt-get update
sudo apt-get install codelite wxcrafter
Ok but then I get missing dependencies:
 codelite : Hängt ab von: libglib2.0-0 (>= 2.41.1) aber 2.40.2-0ubuntu1 soll installiert werden
        Hängt ab von: libhunspell-1.3-0 (>= 1.3.3) aber 1.3.2-6ubuntu2 soll installiert werden
        Hängt ab von: libstdc++6 (>= 4.9) aber 4.8.4-2ubuntu1~14.04 soll installiert werden
        Hängt ab von: libwxbase3.0-0 (>= 3.0.2) aber 3.0.0-2 soll installiert werden
        Hängt ab von: libwxgtk3.0-0 (>= 3.0.2) aber 3.0.0-2 soll installiert werden
Confunsingly, Synaptic shows all packages which are declared missing as installed. Now there has already been this issue in:
How to install CodeLite on Ubuntu?
However, I have no idea how to find the path to the required packages on
http:// ubuntu.intergenia.de for the wget command as in the solution above.
I would really appreciate your help! nbt
tenticon
  • 113
This is strange. If you take a look at the packages file
http://repos.codelite.org/ubuntu/dists/trusty/universe/binary-amd64/Packages
you will find, that the repository offers codelite-8.1-1 for trusty. It depends on libglib2.0-0 (>= 2.24.0), which is perfectly fine.
Please make sure you have no other codelite repos in your sources. Either check under "Software sources" in the Update manager, or issue
apt-cache policy | grep codelite
Deactivate any other repo than the trusty one and run
apt-get update
again.
Nephente
  • 5,875
