I'm running Ubuntu 15.04 with xdm as the display manager, and a custom multi-monitor and keyboard setup defined in xorg.conf.
xdm picks up the keyboard config correctly, setting the layout to "gb", and with the caps and ctrl keys swapped.
However, when I start Window Maker, or any other display manager, I find that my keyboard layout reverts to US. The ctrl/caps keys stay swapped though.
xorg.conf:
Section "Monitor"
        Identifier   "DP1"
EndSection
Section "Monitor"
        Identifier   "HDMI2"
        Option       "LeftOf" "DP1"
        Option       "Rotate" "left"
EndSection
Section "Device"
        Identifier "intel"
        Driver     "intel"
#       Option     "TearFree" "true"
        Option     "Monitor-DP1" "DP1"
        Option     "Monitor-HDMI2" "HDMI2"
EndSection
Section "InputClass"
        Identifier      "caps as ctrl sun gb keyboard"
        Driver          "evdev"
        MatchIsKeyboard "yes"
        Option          "XkbLayout" "gb"
        Option          "XkbModel" "sun_type7_usb"
        Option          "XkbRules" "xorg"
        Option          "XkbOptions" "ctrl:swapcaps"
EndSection
5 Answers5
From your comments to the other answers I can see that you might are not be running a settings daemon. Most DesktopEnvironments (like Gnome, KDE etc.) runs a service for keeping track of every little setting for you! But WindowManagers (like WindowMaker, i3, awesome etc.) usually don't have this feature.
If you are starting a WindowManager from ~/.xsession or other homemade script, then you should set your keyboard settings for that specific session. Setting the keyboard layout can be done with setxkbmap from your Xsession script before the line where you start the WindowManager.
setxkbmap -model sun_type7_usb -layout gb -option ctrl:swapcaps
As a bonus info, you can get all the available models, layouts etc. from these commands:
localectl list-x11-keymap-models
localectl list-x11-keymap-layouts
localectl list-x11-keymap-variants [layout]
localectl list-x11-keymap-options
These informations were primarily found at ArchWiki, where there is some more information about keyboards in general though it may differ a bit from Ubuntu.
If the layout change works on the login screen, but breaks after logging in, it means that the same resources are intercepted by a third-party program. In my case, it was the ibus daemon. It has its own layout settings. I found it by searching among open files by encoding, since I decided that this program should use encoding files:
lsof | grep -i CP1251 | awk '{print $1}' | sort | uniq
(CP1251 is my default locale :) utf-8 in your case) Among browsers, openoffice, pulseaudio a demon ibus was discovered. After deleting it, the layout stopped breaking. (It can also be reconfigured to a non aggressive mode of operation)
  1. Try edit /etc/default/keyboard
    XKBMODEL="sun_type7_usb"
    XKBLAYOUT="gb"
    XKBOPTIONS="ctrl:swapcaps"
  2. To apply, Reboot or run:
    sudo udevadm trigger --subsystem-match=input --action=change
Reference: man keyboard
user.dz
  • 49,176
  • Unity has its own settings daemon that take care of layout setup, which reset any previous Xorg setup.
    1. Check current setting:
      gsettings get org.gnome.desktop.input-sources xkb-options
    2. Then add ctrl:swapcaps to it and set it back.
      gsettings set org.gnome.desktop.input-sources xkb-options "['ctrl:swapcaps']"
    3. Set layout to gb
      gsettings set org.gnome.desktop.input-sources sources [('xkb', 'gb')]
  • If it didn't work, disable keyboard plug-in of settings daemon
    gsettings set org.gnome.settings-daemon.plugins.keyboard active false
    Reference: Permanently set keyboard layout options with setxkbmap in gnome/unity
BTW, You can use GUI tool instead of command line if you want, look for dconf-editor
user.dz
  • 49,176
Have you try this:
    gsettings set org.gnome.setting-daemon.keyboard.layout KEY=active VALUE=true
and it might work fine this way.
Michael
  • 2,597
