I'm using Ubuntu for the first time on my laptop, and everything is fine except that whenever I suspend the system (either manually or by closing the lid) and then resume, I get a completely black screen which forces me to do a hard reset. I tried running pm-suspend --quirk-s3-mode, but when I resumed from that it displayed the screen I had before pressing enter, only it was completely frozen and no key-combos would break it. I've tried searching for solutions, but they've all been for previous versions of Ubuntu. Here are my specs (don't know what's relevant, will add what's necessary):
  • Laptop: Lenovo Z50-70
  • Kernel: Linux 3.19.0-28-generic
  • Display: GF117M with nouveau driver
EDIT: I just tried sudo pm-suspend --quirk-vbemode-restore with the same results as s3-mode. I got an error report on reboot which I submitted, but I don't know where to pull that up so that I can copy it.
Things I've tried:
  • Locking screen, closing lid, then opening and resuming (black screen)
  • Running pm-suspend in virtual console (resumes to virtual console, but frozen)
  • Switching to a proprietary driver and trying the above again (same problems)
EDIT2: Working through the top answer here (though GRUB_CMDLINE_LINUX_DEFAULT="quiet splash pcie_aspm=force" hasn't worked) and then trying this
EDIT3: Error message
yarrok
This is not a solution but another workaround:
If you are using the nvidia card you should switch to the intel one before the suspension, that worked for me (i'm using the proprietary drivers instead of the nouveau ones but i think that should work on your configuration too).
Someone in other posts, like yarrok said, suggests to make a bash script that intercepts the suspension and switches to a virtual console before suspending and switches again on the x-session on restore automatically, but that hasn't worked for me. However, if you find out how to switch your video driver programmatically you could use the same trick to switch it automatically before the suspension and restore it on resume.
The only thing that concerns me is that probably when you switch video driver you have to logout to apply the change.
