I have the issue outlined above in the title - and further explained below - and would greatly appreciate any help on getting it resolved.
To get right down to the problem, I'll start off with an explanation of my setup, and the things I did before the problem.
Current Setup (drives, partitions, OSes, etc.):
->500 GB Disk Drive: Linux Mint 17.2; 4 GB swap space; all located on /dev/sda, specifically sda1 and sda2, respectively.
->1 TB Disk Drive: Windows 7 Pro; located on /dev/sdb, specifically sdb1.
Order of OS installation (pardon the "history lesson"):
In the very beginning, I had installed Windows 7 to the 500 GB drive, and the 1 TB drive hadn't been installed yet. Later, I found out about the awesomeness that is Linux and decided to have it on this computer as the main OS for development and such. I installed it alongside Windows 7, without issue, and the world seemed perfect then. A good time after that, the 1 TB drive arrived and I gave all that to another Windows 7 as a separate partition from the other, older Windows 7. It seems Windows likes rather large files, even in its updates.
Since it isn't all great fun to have about 200 GB to Linux and >1.25 TB for Windows, I wanted to give my Linux install a "bonus" for being so awesome. I just wanted to do it after the latest release of Linux Mint. During the process of installing the new version as a clean installation (and, of course, backing up prior), I had chosen the option of essentially formatting the entire 500 GB drive to a blank state and installing the new version of Linux Mint there with the aforementioned setup. The 1 TB drive was never touched, at least I don't remember so.
After the installation was over and the computer was rebooted, there was no way of accessing the Windows drive. To elaborate, I would get a "BootMGR is missing" error when trying to directly access Windows from the BIOS boot menu, and Windows 7 was unlisted in the GRUB menu. I did manage to "fix" the Windows "BOOTMGR is missing" issue (via Windows 7 install DVD), however Windows will still not load, and instead the computer reboots and directs me back to the GRUB menu, in which the Windows entry is missing anyway. I can access files on my Windows partition through my file manager, as well as mount the drive, without issue.
I have tried tools such as boot-repair, and the Windows installation disk (the latter possibly making the situation worse?), with both not being especially helpful in results.
This concludes my "essay", if you will, and I hope I was thorough enough in my problem's explanation. If there is any material I should post (such as the contents of "grub.cfg") please let me know.
Thank you in advance for your most appreciated help!
EDIT: Here are the contents of "grub.cfg":
### BEGIN /etc/grub.d/00_header ###
if [ -s $prefix/grubenv ]; then
set have_grubenv=true
load_env
fi
if [ "${next_entry}" ] ; then
set default="${next_entry}"
set next_entry=
save_env next_entry
set boot_once=true
else
set default="0"
fi
if [ x"${feature_menuentry_id}" = xy ]; then
menuentry_id_option="--id"
else
menuentry_id_option=""
fi
export menuentry_id_option
if [ "${prev_saved_entry}" ]; then
set saved_entry="${prev_saved_entry}"
save_env saved_entry
set prev_saved_entry=
save_env prev_saved_entry
set boot_once=true
fi
function savedefault {
if [ -z "${boot_once}" ]; then
saved_entry="${chosen}"
fi
function recordfail {
set recordfail=1
if [ -n "${have_grubenv}" ]; then if [ -z "${boot_once}" ]; then save_env recordfail; fi; fi
function load_video {
if [ x$feature_all_video_module = xy ]; then
insmod all_video
else
insmod efi_gop
insmod efi_uga
insmod ieee1275_fb
insmod vbe
insmod vga
insmod video_bochs
insmod video_cirrus
fi
if [ x$feature_default_font_path = xy ] ; then
font=unicode
else
insmod part_msdos
insmod ext2
set root='hd0,msdos1'
if [ x$feature_platform_search_hint = xy ]; then
search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos1 --hint-efi=hd0,msdos1 --hint-baremetal=ahci0,msdos1 952aee30-e9f8-442d-aaa3-0d62e0557c56
else
search --no-floppy --fs-uuid --set=root 952aee30-e9f8-442d-aaa3-0d62e0557c56
fi
font="/usr/share/grub/unicode.pf2"
fi
if loadfont $font ; then
set gfxmode=auto
load_video
insmod gfxterm
set locale_dir=$prefix/locale
set lang=en_US
insmod gettext
fi
terminal_output gfxterm
if [ "${recordfail}" = 1 ] ; then
set timeout=-1
else
if [ x$feature_timeout_style = xy ] ; then
set timeout_style=menu
set timeout=10
# Fallback normal timeout code in case the timeout_style feature is
# unavailable.
else
set timeout=10
fi
fi
### END /etc/grub.d/00_header ###
### BEGIN /etc/grub.d/05_debian_theme ###
set menu_color_normal=white/black
set menu_color_highlight=black/light-gray
if background_color 0,0,0; then
clear
fi
### END /etc/grub.d/05_debian_theme ###
### BEGIN /etc/grub.d/06_mint_theme ###
set menu_color_highlight=white/light-gray
### END /etc/grub.d/06_mint_theme ###
### BEGIN /etc/grub.d/10_linux ###
function gfxmode {
set gfxpayload="${1}"
if [ "${1}" = "keep" ]; then
set vt_handoff=vt.handoff=7
else
set vt_handoff=
fi
if [ "${recordfail}" != 1 ]; then
if [ -e ${prefix}/gfxblacklist.txt ]; then
if hwmatch ${prefix}/gfxblacklist.txt 3; then
if [ ${match} = 0 ]; then
set linux_gfx_mode=keep
else
set linux_gfx_mode=text
fi
else
fi
else
fi
else
fi
export linux_gfx_mode
menuentry 'Linux Mint 17.2 KDE 64-bit' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-952aee30-e9f8-442d-aaa3-0d62e0557c56' {
recordfail
load_video
gfxmode $linux_gfx_mode
insmod gzio
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-3.16.0-38-generic root=UUID=952aee30-e9f8-442d-aaa3-0d62e0557c56 ro quiet splash $vt_handoff
initrd /boot/initrd.img-3.16.0-38-generic
submenu 'Advanced options for Linux Mint 17.2 KDE 64-bit' $menuentry_id_option 'gnulinux-advanced-952aee30-e9f8-442d-aaa3-0d62e0557c56' {
menuentry 'Linux Mint 17.2 KDE 64-bit, with Linux 3.16.0-38-generic' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-3.16.0-38-generic-advanced-952aee30-e9f8-442d-aaa3-0d62e0557c56' {
recordfail
load_video
insmod gzio
insmod part_msdos
insmod ext2
else
fi
echo 'Loading Linux 3.16.0-38-generic ...'
echo 'Loading initial ramdisk ...'
menuentry 'Linux Mint 17.2 KDE 64-bit, with Linux 3.16.0-38-generic (recovery mode)' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-3.16.0-38-generic-recovery-952aee30-e9f8-442d-aaa3-0d62e0557c56' {
recordfail
load_video
insmod gzio
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-3.16.0-38-generic root=UUID=952aee30-e9f8-442d-aaa3-0d62e0557c56 ro recovery nomodeset
### END /etc/grub.d/10_linux ###
### BEGIN /etc/grub.d/20_linux_xen ###
### END /etc/grub.d/20_linux_xen ###
### BEGIN /etc/grub.d/20_memtest86+ ###
menuentry 'Memory test (memtest86+)' {
insmod part_msdos
insmod ext2
else
fi
knetbsd /boot/memtest86+.elf
menuentry 'Memory test (memtest86+, serial console 115200)' {
insmod part_msdos
insmod ext2
else
fi
linux16 /boot/memtest86+.bin console=ttyS0,115200n8
### END /etc/grub.d/20_memtest86+ ###
### BEGIN /etc/grub.d/30_os-prober ###
### END /etc/grub.d/30_os-prober ###
### BEGIN /etc/grub.d/30_uefi-firmware ###
### END /etc/grub.d/30_uefi-firmware ###
### BEGIN /etc/grub.d/40_custom ###
# This file provides an easy way to add custom menu entries. Simply type the
# menu entries you want to add after this comment. Be careful not to change
# the 'exec tail' line above.
### END /etc/grub.d/40_custom ###
### BEGIN /etc/grub.d/41_custom ###
if [ -f ${config_directory}/custom.cfg ]; then
source ${config_directory}/custom.cfg
elif [ -z "${config_directory}" -a -f $prefix/custom.cfg ]; then
source $prefix/custom.cfg;
fi
### END /etc/grub.d/41_custom ###
