Hello everyone so I have been running Debian Linux for a while and decided to switch back over and dual boot with Ubuntu to play games again. I did a fresh install of Ubuntu 14.04
I installed Steam from the software center and it installed and I went to run it from the terminal by typing in steam
This is what I get :
Steam needs to install these additional packages:
    libgl1-mesa-dri:i386, libgl1-mesa-glx:i386, libc6:i386
Reading package lists... Done
Building dependency tree
 libgl1-mesa-glx:i386 : Depends: libglapi-mesa:i386 (= 10.1.3-0ubuntu0.4)
 unity-control-center : Depends: libcheese-gtk23 (>= 3.4.0) but it is not going to be installed
                        Depends: libcheese7 (>= 3.0.1) but it is not going to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
Press return to continue:
That is the error I receive. This is a fresh brand new install the only thing I have installed in steam if I could please get help with that it would be amazing. Thank you very much.
hg8
  • 13,582
First, search for an application called "software & updates".
Open this application.
Next, make sure main, universe, restricted, and multiverse are all enabled.
Now, before you try and go installing new software, you need to do all your system upgrades first:
sudo apt-get clean
sudo apt-get update
sudo apt-get dist-upgrade
Reboot when finished. Then you can install steam:
sudo apt-get install libc6-i386 steam
mchid
  • 44,904
  • 102
  • 162
