After fixing another issue with missing packages, this is what I get when I try to startup steam:
Running Steam on ubuntu 14.04 64-bit
STEAM_RUNTIME is enabled automatically
Installing breakpad exception handler for appid(steam)/version(0)
libGL error: No matching fbConfigs or visuals found
libGL error: failed to load driver: swrast
I've tried reinstalling several times, didn't work. Also tried deleting the appcache like some other answers said.
Any help greatly appreciated.
ps. what do I have to learn to understand these error messages
Reading package lists... Done
Building dependency tree
 gnome-control-center : Depends: libcheese-gtk23 (>= 3.4.0) but it is not going to be installed
                        Depends: libcheese7 (>= 3.0.1) but it is not going to be installed
 unity-control-center : Depends: libcheese-gtk23 (>= 3.4.0) but it is not going to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
mchid
  • 44,904
  • 102
  • 162
uniqueID
  • 73
Run the following command to install that driver (swrast_dri.so):
sudo apt-get update
sudo apt-get install libgl1-mesa-dri libgl1-mesa-dri:i386
Please post any errors, thanks!
Usually, when I've seen this error, running:
sudo apt-get clean
sudo apt-get update
sudo apt-get dist-upgrade
fixed the issue.
However, sometimes you may need to try and install (or uninstall) stubborn applications individually to get things done.
To understand the message, install the needed dependencies individually to see what the issue is (or this may fix the issue):
sudo apt-get install --reinstall libcheese-gtk23 libcheese7
If the next error message says blah blah blah depends on blah blah blah, try installing blah blah blah and go from there.
mchid
  • 44,904
  • 102
  • 162
