I am trying to install php5-cli package on my machine but I get the following error for unmet dependencies.
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these:
 libmaven2-core-java : Depends: libdoxia-core-java (>= 1.1) but it is not going to be installed
 php5-cli : Depends: libonig2 (>= 5.9.5) but it is not going to be installed
            Depends: libqdbm14 (>= 1.8.74) but it is not going to be installed
            Depends: php5-common (= 5.6.12+dfsg-1+deb.sury.org~vivid+1) but it is not going to be installed
            Depends: php5-json but it is not going to be installed
            Recommends: php5-readline but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
I have tried apt-get install -f, apt-get clean and apt-get autoclean none of which helped. I have tried almost all the solutions given in this post How do I resolve unmet dependencies after adding a PPA? but none of them seemed to work for me.
edit:I tried installing the packages individually using
sudo apt-get install php5-readline php5-json php5-common libqdbm14 libonigia-core-java libmaven2-core-java 2 libdox
but that didn't seem to work either.
libonig2 is already the newest version.
libmaven2-core-java is already the newest version.
libmaven2-core-java set to manually installed.
libqdbm14 is already the newest version.
php5-common is already the newest version.
php5-json is already the newest version.
 php5-readline : Depends: php5-cli (= 5.6.12+dfsg-1+deb.sury.org~vivid+1) but it is not going to be installed
Here is the output for apt-cache policy php5-readline
php5-readline:
  Installed: (none)
  Candidate: 5.6.12+dfsg-1+deb.sury.org~vivid+1
  Version table:
     5.6.12+dfsg-1+deb.sury.org~vivid+1 0
        500 http://ppa.launchpad.net/ondrej/php5-5.6/ubuntu/ vivid/main amd64 Packages
     5.6.12+dfsg-1 0
        500 http://ftp.us.debian.org/debian/ unstable/main amd64 Packages
     5.6.4+dfsg-4ubuntu6.2 0
        500 http://pk.archive.ubuntu.com/ubuntu/ vivid-updates/main amd64 Packages
        500 http://security.ubuntu.com/ubuntu/ vivid-security/main amd64 Packages
     5.6.4+dfsg-4ubuntu6 0
        500 http://pk.archive.ubuntu.com/ubuntu/ vivid/main amd64 Packages
the output to grep -r 'ftp.us.debian.org' /etc/apt/ and apt-cache policy libmaven2-core-java is
/etc/apt/sources.list:deb http://ftp.us.debian.org/debian unstable main contrib non-free
/etc/apt/sources.list.save:deb http://ftp.us.debian.org/debian unstable main contrib non-free
/etc/apt/sources.list.bak:deb http://ftp.us.debian.org/debian unstable main contrib non-free
grep: and: No such file or directory
grep: apt-cache: No such file or directory
grep: policy: No such file or directory
grep: libmaven2-core-java: No such file or directory
And this is the output to the script:
alsa-base http://ftp.us.debian.org/debian/ unstable/main amd64 Packages
cgroupfs-mount http://ftp.us.debian.org/debian/ unstable/main amd64 Packages
curl http://ftp.us.debian.org/debian/ unstable/main amd64 Packages
dmsetup http://ftp.us.debian.org/debian/ unstable/main amd64 Packages
dnsmasq-base http://ftp.us.debian.org/debian/ unstable/main amd64 Packages
libarchive13 http://ftp.us.debian.org/debian/ unstable/main amd64 Packages
libcurl3-gnutls http://ftp.us.debian.org/debian/ unstable/main amd64 Packages
libdevmapper1.02.1 http://ftp.us.debian.org/debian/ unstable/main amd64 Packages
libeclipse-aether-java http://ftp.us.debian.org/debian/ unstable/main amd64 Packages
libgnutls-deb0-28 http://ftp.us.debian.org/debian/ unstable/main amd64 Packages
libgnutls-openssl27 http://ftp.us.debian.org/debian/ unstable/main amd64 Packages
libgrpc-dev http://ftp.us.debian.org/debian/ unstable/main amd64 Packages
libgrpc0 http://ftp.us.debian.org/debian/ unstable/main amd64 Packages
libhogweed4 http://ftp.us.debian.org/debian/ unstable/main amd64 Packages
libjsch-java http://ftp.us.debian.org/debian/ unstable/main amd64 Packages
libnettle6 http://ftp.us.debian.org/debian/ unstable/main amd64 Packages
librtmp1 http://ftp.us.debian.org/debian/ unstable/main amd64 Packages
libsisu-inject-java http://ftp.us.debian.org/debian/ unstable/main amd64 Packages
libssh2-1 http://ftp.us.debian.org/debian/ unstable/main amd64 Packages
libssl-dev http://ftp.us.debian.org/debian/ unstable/main amd64 Packages
libssl1.0.0 http://ftp.us.debian.org/debian/ unstable/main amd64 Packages
libtasn1-6 http://ftp.us.debian.org/debian/ unstable/main amd64 Packages
libunwind8 http://ftp.us.debian.org/debian/ unstable/main amd64 Packages
libwagon-java http://ftp.us.debian.org/debian/ unstable/main amd64 Packages
libwagon2-java http://ftp.us.debian.org/debian/ unstable/main amd64 Packages
pepperflashplugin-nonfree http://ftp.us.debian.org/debian/ unstable/contrib amd64 Packages
output for apt-cache policy libmaven2-core-java
  Installed: 2.2.1-22
  Candidate: 2.2.1-22
  Version table:
 *** 2.2.1-22 0
        100 /var/lib/dpkg/status
     2.2.1-17 0
        500 http://archive.ubuntu.com/ubuntu/ vivid/universe amd64 Packages
I followed the steps in the answer, removed the repository, ran apt-get -f install and had to do an autoremove to remove some packages that were not required anymore. It seemed to have resolved the issue with libmaven2-core-java. I then tried to install php5-cli again but I got the following output.
 php5-cli : Depends: php5-common (= 5.6.4+dfsg-4ubuntu6.2) but 5.6.12+dfsg-1+deb.sury.org~vivid+1 is to be installed
output to sudo apt-get install -f
0 upgraded, 0 newly installed, 0 to remove and 53 not upgraded
and output to sudo apt-get install php5-cli
the output for apt-cache policy php5-common
php5-common:
  Installed: 5.6.12+dfsg-1+deb.sury.org~vivid+1
  Version table:
 *** 5.6.12+dfsg-1+deb.sury.org~vivid+1 0
        500 http://archive.ubuntu.com/ubuntu/ vivid-updates/main amd64 Packages
        500 http://archive.ubuntu.com/ubuntu/ vivid/main amd64 Packages
The output to dpkg -l | grep 'sury' is
ii  php5-json                                            1.3.7-1+deb.sury.org~vivid+1               amd64        JSON module for php5
SHuss
  • 33
You have incompatible software repositories enabled. We can fix this…
  1. Use the main server for the Ubuntu repositories
    sudo sed -i.bak 's/http:\/\/pk\./http:\/\//' /etc/apt/sources.list
    sudo apt-get update
  2. Install ppa-purge
    sudo apt-get install ppa-purge
    If an installation isn't possible and ppa-purge isn't installed, download the deb package
    cd ..
    wget http://mirrors.kernel.org/ubuntu/pool/universe/p/ppa-purge/ppa-purge_0.2.8+bzr57_all.deb
    extract and copy the executable
    dpkg -x ppa-purge_0.2.8+bzr57_all.deb ppa-purge
    sudo cp ppa-purge/usr/sbin/ppa-purge /usr/sbin
  3. Purge the PPA ppa:ondrej/php5-5.6
    sudo ppa-purge ppa:ondrej/php5-5.6
    sudo apt-get update
  4. The next error message
    You use an additionally Debian repository, http://ftp.us.debian.org/. This repository provides libmaven2-core-java which depends on libdoxia-core-java. But this package isn't available.
    Therefore remove the repository http://ftp.us.debian.org/ in your /etc/apt/sources.list. After that, run
    sudo apt-get update
    and downgrade the packages with:
    sudo apt-get install libmaven2-core-java=2.2.1-17
  5. Usually not necessary after purging the PPA ppa:ondrej/php5-5.6 with ppa-purge, but in your case downgrade also the packages listed by dpkg -l | grep 'sury'
    sudo apt-get install php5-common=5.6.4+dfsg-4ubuntu6.2
    sudo apt-get install php5-json=1.3.2-2build1
  6. Repair your installation
A.B.
  • 92,125
