So I'm just coming back to Ubuntu after some time away, running 14.04 and I've gotten things customized the way I like them, more or less. At one point I'd attempted to download "Popcorn-Time." I ran into some issues of some sort and decided to remove it/that it wasn't worth the trouble.
Something from the install process seems to be "stuck" in apt-get though. I'm having issues getting new packages and I'm getting this message:
Processing triggers for man-db (2.6.7.1-1ubuntu1) ...
Setting up popcorn-time (0.3.2~webupd8~6) ...
Downloading Popcorn Time...
--2015-09-06 11:25:00--  http://cdn.popcorntime.io/build/Popcorn-Time ...
Resolving cdn.popcorntime.io ...
Connecting to cdn.popcorntime.io (cdn.popcorntime.io)|45.33.69.37|:80... connected.
HTTP request sent, awaiting response... 404 Not Found
2015-09-06 11:25:00 ERROR 404: Not Found.
download failed
Popcorn Time is NOT installed.
dpkg: error processing package popcorn-time (--configure):
 subprocess installed post-installation script returned error exit status 1
 popcorn-time
I've omitted a couple of lines there, but I think you get the idea. This is occurring when I try to install most packages using apt-get, maybe all packages. It seems like it's interfering, and frankly I'd like it to not try to install popcorn time every time I install any package.
Any ideas?
MattB
  • 151
Turned out I needed to remove it from dpkg:
dpkg -r popcorn-time
And that took care of it for me. Thanks again for the help and suggestions everyone!
MattB
  • 151
Since its site seems to be down try removing the popcorntime.io PPA: E.g. See this post
Then do an sudo apt-get update and apt should be ok.
Hinz
  • 592
