10
I have a Lenovo Thinkpad e540 laptop with dual graphics, Intel integrated and Nvidia GT 740m Discrete. After changing from nouveau drivers to Nvidia binary driver 346.82 proprietary before login screen I've got a message:
[0.646495]Error parsing PCC subspaces from PCCT
[0.646521]ACPI PCC probe failed.
Kernel version:
3.19.0-26-generic #28~14.04.1-Ubuntu SMP Wed Aug 12 14:09:17 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
I've read somewhere that if I put in grub file quiet splash nomodeset that will fix this, but that doesn't work for me, then I get into login loop.
How can I fix this?
Nicolas Raoul
  • 11,921
I had the same problem after installing Ubuntu 16.04 on the Lenovo w540 with preinstalled Win 8.1. It appeared that I didn't install Ubuntu with correct bootloader. The Windows was booting in UEFI mode while the Ubuntu in BIOS mode.So I've reinstalled Ubuntu, but this time I read:
  1. When I created a bootable USB key from the ISO image I made sure it will boot in UEFI mode = I used Rufus and chose 'GPR partition for UEFI' as a partition type for the bootable USB key (they say that there is a version of YUMI that support UEFI as well - didn't try it though )
  2. In my BIOS settings I've disallowed booting other than UEFI to make sure my USB key will boot with UEFI (I did the opposite of https://neosmart.net/wiki/enable-legacy-boot-mode/).
  3. The Ubuntu knew that it was booted from UEFI bootloader and it installed with UEFI bootloader as well.
The problem with the PCC parsing... didn't appear since then.
I don't know if it's relevant but I've installed Ubuntu on a separate drive with separate efi partition.In my BIOS settings I have now another entry on the boot order list: 'ubuntu'. It was placed by the Ubuntu installer on the first place so I moved it below the USB stuff but above the Windows Boot Manager so I can boot from USB key or choose from the GRUB2 boot menu which system to boot on each restart.
arundai
  • 81
Due to the response on the comment, and that it apparently works...
Answer: Usually happens on Linux-Windows dual boot. Disable hiberboot (fast startup) in Windows. If it comes back after some upgrade, just boot to Windows and restart, worked on my friend's PC.
Windows > Control Panel > All Control Panel Items > Power Options > System Settings > Change settings that are currently unavailable (UAC) > Turn on fast startup (recommended) — unchecked this.
Note: Well, it really isn't recommended to dual boot Windows with Linux.
References:
Windows 10 - http://www.tenforums.com/tutorials/4189-fast-startup-turn-off-windows-10-a.html
Windows 8 - http://www.trishtech.com/2013/07/how-to-disable-hiberboot-in-windows-8/
Majal
  • 8,249
I've solved the problem on my lenovo thinkpad edge E540 by changing the nvidia driver used.
The Nvidia 340 generates the problem. With a driver more up to date, it works. First add the bumblebee package, then run the software updater of sudo apt update and new nvidia drivers become available. Select a more recent driver and let it install. You must then deactivate this package from the updates because it prevents Ubuntu from getting the updates of the xenial version.
Zanna
  • 72,312
regis
I had this on Yoga 3 14 80JH
The bios upgrade and fix from lenovo support fix this. Unfortunately there is no ISO image to run bios update. You need to install Windows 10 to install patch and to flash bios.
TAdam
