-1
Hi computer geeks and nerds, i am in no way a computer guru. My sony viao S series laptop decided to break after just a year. My hard drive failed meaning it held all my work and files including 5year uni work that i hadnt backed up. so i created a live CD using ubuntu.
After a long attempt to get it to load on my computer it finally did. In the ubuntu disk usage analyser i see my files size in 'gb' but i am unable to drag them into my USB for backing up.
When i try to drag it says i have no permission to do so (root owned the folders).
Next i added a new account which is myself as administrator but this only logged me out and asked for password which i never had to begin with.
My weak laptop was on for hours trying to figure this out so i had to shut it down direct from the ubuntu desktop to preserve its life.
please advice what do i do now?.
What is the best option to get my files from my hard drive without further damage to my hard drive etc. Also i tried a bunch of several commands and terminals i found online before then adding new user account none of which worked.
PLEASE help!. I will be keeping a close eye in the next 30mins. Please help me.
Thankyou
Pilot6
  • 92,041
Hold CTRL+Alt then hit T
A Terminal window should open, and you will see a $-prompt where you may type commands.
Type sudo -i nautilus & and hit Enter
This should open "Files" (Ubuntu default file manager) and allow to read (and possibly write to) your old HD.
If that does not work, then your most viable option is using "Testdisk" which is described here
Please read the entrie posting, and note that the actual instruction begin at
Boot your Ubuntu LiveCD ("Try Ubuntu")
Note that you also have special sections later in the answer that helps in using file-copy type recovery - that starts at:
Copy data from the live system to an external drive ... which adds to what is above, at the beginning of this answer.
Hannu
  • 6,605
  • 28
  • 45
