I am new to Ubuntu 14.04 LTS and I just installed it today on my Lenovo G50-70 laptop. Before marking this as duplicate, please hear me out. I have read countless posts on this issue, but none have been able to help me. I am having an issue with the WiFi that I didn't have with Windows 10, my previous OS. This issue started since installing Ubuntu when I was trying to install updates. The Internet on my laptop goes out randomly, but all other computers are fine so it can't be my router. Sometimes it stops working after a minute after reboot and sometimes an hour. It's random as to when it will stop working and once it's gone, it doesn't come back unless I reboot. I have 2 Windows 10 machines and another Ubuntu 14.04 machine that my brother runs that is fine. The Internet issue I am facing resolves upon reboot, but it occurs again randomly when I'm browsing and is not fixed by enabling/disabling WiFi or disconnecting/reconnecting. I have to restart the computer to fix the wifi. I ran the command dmesg before the Internet could go out again and got the result. I am unable to post it on here since there's a character limit, but I have the result in a text file. I have also tried to change my ipv6 settings to Link-Local Only, but that didn't resolve the issue. Also, the WiFi icon says that my Internet is fine, but it isn't. Pinging in the terminal also does not work when the Internet is gone, even though the WiFi icon is still active.
After the Internet went out, I ran the command lcpci -v and got:
00:00.0 Host bridge: Intel Corporation Haswell-ULT DRAM Controller (rev 0b)
Subsystem: Lenovo Device 3978
Flags: bus master, fast devsel, latency 0
Capabilities: <access denied>
00:02.0 VGA compatible controller: Intel Corporation Haswell-ULT Integrated Graphics Controller (rev 0b) (prog-if 00 [VGA controller])
Subsystem: Lenovo Device 380c
Flags: bus master, fast devsel, latency 0, IRQ 47
Memory at c0000000 (64-bit, non-prefetchable) [size=4M]
Memory at b0000000 (64-bit, prefetchable) [size=256M]
I/O ports at 5000 [size=64]
Expansion ROM at <unassigned> [disabled]
Kernel driver in use: i915
00:03.0 Audio device: Intel Corporation Haswell-ULT HD Audio Controller (rev 0b)
Flags: bus master, fast devsel, latency 0, IRQ 48
Memory at c0610000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: snd_hda_intel
00:14.0 USB controller: Intel Corporation Lynx Point-LP USB xHCI HC (rev 04) (prog-if 30 [XHCI])
Flags: bus master, medium devsel, latency 0, IRQ 42
Memory at c0600000 (64-bit, non-prefetchable) [size=64K]
Kernel driver in use: xhci_hcd
00:16.0 Communication controller: Intel Corporation Lynx Point-LP HECI #0 (rev 04)
Flags: bus master, fast devsel, latency 0, IRQ 45
Memory at c0618000 (64-bit, non-prefetchable) [size=32]
Kernel driver in use: mei_me
00:1b.0 Audio device: Intel Corporation Lynx Point-LP HD Audio Controller (rev 04)
Flags: bus master, fast devsel, latency 0, IRQ 46
Memory at c0614000 (64-bit, non-prefetchable) [size=16K]
00:1c.0 PCI bridge: Intel Corporation Lynx Point-LP PCI Express Root Port 3 (rev e4) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 00004000-00004fff
Memory behind bridge: c0500000-c05fffff
Kernel driver in use: pcieport
00:1c.3 PCI bridge: Intel Corporation Lynx Point-LP PCI Express Root Port 4 (rev e4) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 00003000-00003fff
Memory behind bridge: c0400000-c04fffff
00:1d.0 USB controller: Intel Corporation Lynx Point-LP USB EHCI #1 (rev 04) (prog-if 20 [EHCI])
Flags: bus master, medium devsel, latency 0, IRQ 23
Memory at c061c000 (32-bit, non-prefetchable) [size=1K]
Kernel driver in use: ehci-pci
00:1f.0 ISA bridge: Intel Corporation Lynx Point-LP LPC Controller (rev 04)
Kernel driver in use: lpc_ich
00:1f.2 SATA controller: Intel Corporation Lynx Point-LP SATA Controller 1 [AHCI mode] (rev 04) (prog-if 01 [AHCI 1.0])
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 43
I/O ports at 5088 [size=8]
I/O ports at 5094 [size=4]
I/O ports at 5080 [size=8]
I/O ports at 5090 [size=4]
I/O ports at 5060 [size=32]
Memory at c061b000 (32-bit, non-prefetchable) [size=2K]
Kernel driver in use: ahci
00:1f.3 SMBus: Intel Corporation Lynx Point-LP SMBus Controller (rev 04)
Flags: medium devsel
Memory at c0619000 (64-bit, non-prefetchable) [size=256]
I/O ports at 5040 [size=32]
01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 10)
Subsystem: Lenovo Device 380a
Flags: bus master, fast devsel, latency 0, IRQ 44
I/O ports at 4000 [size=256]
Memory at c0504000 (64-bit, non-prefetchable) [size=4K]
Memory at c0500000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: r8169
02:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8723BE PCIe Wireless Network Adapter
Subsystem: Lenovo Device b736
Flags: bus master, fast devsel, latency 0, IRQ 19
I/O ports at 3000 [size=256]
Memory at c0400000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: rtl8723be
I then ran ifconfig and got:
eth0 Link encap:Ethernet HWaddr 68:f7:28:18:33:e0
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:1392 errors:0 dropped:0 overruns:0 frame:0
TX packets:1392 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:125457 (125.4 KB) TX bytes:125457 (125.4 KB)
wlan0 Link encap:Ethernet HWaddr c0:38:96:12:bd:c7
inet addr:192.168.1.129 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::c238:96ff:fe12:bdc7/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:4186 errors:0 dropped:0 overruns:0 frame:0
TX packets:4472 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:4124758 (4.1 MB) TX bytes:810905 (810.9 KB)
I would greatly appreciate if someone could help me on this issue. If you need the results for dmesg, please let me know so that I can post it. Thank you for your time.
