I'm having a weird problem with my computer where my wifi stops working some time after my computer starts up. The only way to get it working again is to restart my computer. I know the problem is not with any of the hardware because it works perfectly fine with the Windows 10 I dual boot with.
System info
Manufacturer: Lenovo
Model: G50-70
OS: 64-bit Ubuntu 14.04 LTS
Kernel: 3.16.0-46-generic
This problem also occurs in:
OS: 64-bit Ubuntu 15.04
Kernel: 3.18.21-031821-generic
Network controller info:
  *-network
       description: Ethernet interface
       product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
       vendor: Realtek Semiconductor Co., Ltd.
       physical id: 0
       bus info: pci@0000:01:00.0
       logical name: eth0
       version: 10
       serial: 28:d2:44:e1:6f:15
       capacity: 1Gbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8168 driverversion=8.040.00-NAPI duplex=half latency=0 link=no multicast=yes port=twisted pair speed=10Mbit/s
       resources: irq:43 ioport:4000(size=256) memory:c0504000-c0504fff memory:c0500000-c0503fff
  *-network
       description: Wireless interface
       product: RTL8723BE PCIe Wireless Network Adapter
       physical id: 0
       bus info: pci@0000:02:00.0
       logical name: wlan0
       version: 00
       serial: 38:b1:db:7c:18:bd
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
       configuration: broadcast=yes driver=rtl8723be driverversion=3.18.21-031821-generic firmware=N/A ip=192.168.0.66 latency=0 link=yes multicast=yes wireless=IEEE 802.11bgn
       resources: irq:19 ioport:3000(size=256) memory:c0400000-c0403fff
Please post any comments if you need additional info.
Update:
Switching the router over to WEP encryption seems to fix the problem. However, WEP is insecure so it would be appreciated if a different fix was found.
Update:
This problem is also in Ubuntu 15.10. However, you can simply disconnect and then reconnect in order to solve the problem temporarily. After 2 minutes to 2 hours, the problem happens again.
Similar Questions:
Internet Randomly Stops Working, But Starts Working Again Upon Reboot
Wireless keeps cutting out every several minutes on a Realtek RTL8187SE
