I recently upgraded to 15.04 and immediately after, Matlab 2012b no longer worked and crashed either as soon as it loads the program, or a few moments after I try to do anything. I tried installing a newer version of Matlab, 2013a, but the issue remains.
I've seen one or two other posts similar, but they seem to be related to java, and I don't think this is the case for me (I could be wrong!), and I'm not entirely sure how to find the specific issue from the error message.
The error message says MATLAB has encountered an internal problem and needs to close.
and here's the details for the message:
MATLAB crash file:/home/james/matlab_crash_dump.10850-1:
Segmentation violation detected at Sun Aug 30 22:37:24 2015
Configuration:
Crash Decoding : Disabled
Current Visual : 0x20 (class 4, depth 24)
Default Encoding : UTF-8
GNU C Library : 2.21 stable
MATLAB Architecture: glnxa64
MATLAB Root : /usr/local/MATLAB/R2013a
MATLAB Version : 8.1.0.604 (R2013a)
Operating System : Linux 3.19.0-26-generic #28-Ubuntu SMP Tue Aug 11 14:16:32 UTC 2015 x86_64
Processor ID : x86 Family 6 Model 23 Stepping 6, GenuineIntel
Virtual Machine : Java 1.6.0_17-b04 with Sun Microsystems Inc. Java HotSpot(TM) 64-Bit Server VM mixed mode
Window System : The X.Org Foundation (11701000), display :0
Fault Count: 1
Abnormal termination:
Register State (from fault):
RAX = 00007f2cde2cb9b0 RBX = 00007f2ccc09cb20
RCX = 00007f2cda656da0 RDX = 00000000fffffffd
RSP = 00007f2cda656d40 RBP = 00007f2ccc03ed80
RSI = 00007f2ccc09cb20 RDI = 00007f2c00000000
R8 = 00007f2ccc075108 R9 = 00007f2cde83f2a0
R10 = 00007f2cde83f300 R11 = 000000000000000b
R12 = 00000000fffffffd R13 = 00007f2ccc02b1d0
R14 = 00007f2cda656da0 R15 = 0000000000000004
RIP = 00007f2cec0d1c84 EFL = 0000000000010202
CS = 0033 FS = 0000 GS = 0000
Stack Trace (from fault):
[ 0] 0x00007f2cec0d1c84 /lib/x86_64-linux-gnu/libpthread.so.0+00040068 pthread_mutex_lock+00000004
[ 1] 0x00007f2cde2bbbc1 /usr/lib/x86_64-linux-gnu/libX11.so.6+00109505 XFindContext+00000097
[ 2] 0x00007f2cdebbc388 /usr/local/MATLAB/R2013a/bin/glnxa64/../../sys/os/glnxa64/libXm.so.3+01483656 _XmGetWidgetExtData+00000056
[ 3] 0x00007f2cdebb546b /usr/local/MATLAB/R2013a/bin/glnxa64/../../sys/os/glnxa64/libXm.so.3+01455211 _XmGetFocusPolicy+00000059
[ 4] 0x00007f2cdebb65bd /usr/local/MATLAB/R2013a/bin/glnxa64/../../sys/os/glnxa64/libXm.so.3+01459645 _XmManagerFocusOut+00000061
[ 5] 0x00007f2cde6213ae /usr/lib/x86_64-linux-gnu/libXt.so.6+00291758
[ 6] 0x00007f2cde6217f4 /usr/lib/x86_64-linux-gnu/libXt.so.6+00292852
[ 7] 0x00007f2cde622620 /usr/lib/x86_64-linux-gnu/libXt.so.6+00296480 _XtTranslateEvent+00001568
[ 8] 0x00007f2cde5fbc9b /usr/lib/x86_64-linux-gnu/libXt.so.6+00138395 XtDispatchEventToWidget+00001115
[ 9] 0x00007f2cde5fcaf2 /usr/lib/x86_64-linux-gnu/libXt.so.6+00142066 _XtSendFocusEvent+00000210
[ 10] 0x00007f2cde5fbc4b /usr/lib/x86_64-linux-gnu/libXt.so.6+00138315 XtDispatchEventToWidget+00001035
[ 11] 0x00007f2cde5fc348 /usr/lib/x86_64-linux-gnu/libXt.so.6+00140104
[ 12] 0x00007f2cde5fc499 /usr/lib/x86_64-linux-gnu/libXt.so.6+00140441 XtDispatchEvent+00000201
[ 13] 0x00007f2cde6079be /usr/lib/x86_64-linux-gnu/libXt.so.6+00186814 XtAppProcessEvent+00000734
[ 14] 0x00007f2ce1ad34d3 /usr/local/MATLAB/R2013a/bin/glnxa64/libmwuix.so+00480467
[ 15] 0x00007f2ce1ae0df2 /usr/local/MATLAB/R2013a/bin/glnxa64/libmwuix.so+00536050
[ 16] 0x00007f2cee639862 /usr/local/MATLAB/R2013a/bin/glnxa64/libmwservices.so+01845346
[ 17] 0x00007f2cee63a50f /usr/local/MATLAB/R2013a/bin/glnxa64/libmwservices.so+01848591 _Z25svWS_ProcessPendingEventsiib+00001615
[ 18] 0x00007f2cedf4f5ef /usr/local/MATLAB/R2013a/bin/glnxa64/libmwmcr.so+00316911
[ 19] 0x00007f2cedf4ff5c /usr/local/MATLAB/R2013a/bin/glnxa64/libmwmcr.so+00319324
[ 20] 0x00007f2cedf49592 /usr/local/MATLAB/R2013a/bin/glnxa64/libmwmcr.so+00292242
[ 21] 0x00007f2cec0cf6aa /lib/x86_64-linux-gnu/libpthread.so.0+00030378
[ 22] 0x00007f2cebe04eed /lib/x86_64-linux-gnu/libc.so.6+01076973 clone+00000109
If this problem is reproducible, please submit a Service Request via:
http://www.mathworks.com/support/contact_us/
A technical support engineer might contact you with further information.
Thank you for your help.
And ideas as to what might be causing this error? I tried installing the matlab-support package from apt-get, but it seemed not to solve it.
--------------------------------UPDATE------------------------
I had another go at the issue, and I discovered that Matlab does now work when I use sudo and launch from terminal. This is pretty strange, as I didn't have to use sudo before the 15.04 upgrade.
I've tried to fix this by changing the chown of the matlab installation directory and the .matlab to my username, but no luck. So it looks like the upgrade to 15.04 resulted in a permissions error.
Any ideas on how I can resolve this? Having to use sudo for each launch means I can't use .desktop launchers for matlab, which makes things inconvenient... any ideas?
