I would like to record some text-to-speech. Right now I pipe the audio to play so that it can be played. The command that I use to play the tts is play -q -
I have tried using audio-record and arecord -f cd -t raw | lame -x -r - out.mp3 which I found online but I only hear static. With the rec command, I can't hear anything.
I don't know what else to do or what to check since I'm not very experience with Ubuntu.
Zanna
  • 72,312
If you want to record audio, you can use this ppa although ppas are untrusted:
sudo add-apt-repository ppa:osmoma/audio-recorder
sudo apt-get update
sudo apt-get install audio-recorder
This won't work on 15.10+. If you are using 15.10+ let me know and I'll post instructions on how to install on newer versions.
Here are the instructions for later versions (Ubuntu 15.X, 16.X, & 17.X):
sudo add-apt-repository ppa:audio-recorder/ppa
sudo apt-get -y update
sudo apt-get install --reinstall audio-recorder
Click here for more info and for instructions on removing the old ppa if needed.
mchid
  • 44,904
  • 102
  • 162
-1
To @mchid and others: Audio-recorder for 15.10 has been released. There is a new PPA that belongs to the team. Plase see: http://ubuntuforums.org/showthread.php?t=2295381
