I was trying to uninstall LibreOffice from my Ubuntu 15.04 running Xfce. I typed the following command in the Terminal:
sudo apt-get --purge libre*
It took a while before I realised that the process was erasing more than I needed, since components such as dpkg, gimp, compiz, have also been removed.
Is there any way to check the extent of the damage that has been done and recover? I must say that I cannot reinstall the operating system at the moment.
Thank you.
The command
does exactly nothing it is wrong
E: Command line option --purge is not understood
If you have used the next command (in my test in a bash shell it does also nothing? ...)
sudo apt-get purge libre*
use the command below to identify the purged packages for a given date, eg for 2015-08-28
awk '/Start-Date: 2015-08-28/,/End-Date: 2015-08-28/ {if ($0 ~ /Purge/) {sub(/Purge: /,"",$0); print $0}}' /var/log/apt/history.log
Check the list and reinstall the purged packages via
awk '/Start-Date: 2015-08-28/,/End-Date: 2015-08-28/ {if ($0 ~ /Purge/) {sub(/Purge: /,"",$0); print $0}}' /var/log/apt/history.log | awk '{for (i=i;i<=NF;i++) {if (i%2 == 1) {system("sudo apt-get install -y "$i)}}}'
Example
I've started the command below
sudo apt-get purge librevenge-0.0-0
I get the following output
% awk '/Start-Date: 2015-08-28/,/End-Date: 2015-08-28/ {if ($0 ~ /Purge/) {sub(/Purge: /,"",$0); print $0}}' /var/log/apt/history.log
libreoffice-pdfimport:amd64 (5.0.1~rc2-0ubuntu1~vivid1)
libmspub-0.1-1:amd64 (0.1.1-2)
libreoffice-base-core:amd64 (5.0.1~rc2-0ubuntu1~vivid1)
libreoffice:amd64 (5.0.1~rc2-0ubuntu1~vivid1)
libwpg-0.3-3:amd64 (0.3.0-3)
libreoffice-writer:amd64 (5.0.1~rc2-0ubuntu1~vivid1)
libmwaw-0.3-3:amd64 (0.3.4-1)
libvisio-0.1-1:amd64 (0.1.0-2)
libreoffice-impress:amd64 (5.0.1~rc2-0ubuntu1~vivid1)
libreoffice-help-de:amd64 (5.0.1~rc2-0ubuntu1~vivid1)
libreoffice-avmedia-backend-gstreamer:amd64 (5.0.1~rc2-0ubuntu1~vivid1)
libreoffice-base:amd64 (5.0.1~rc2-0ubuntu1~vivid1)
librevenge-0.0-0:amd64 (0.0.1-3)
libreoffice-draw:amd64 (5.0.1~rc2-0ubuntu1~vivid1)
libreoffice-core:amd64 (5.0.1~rc2-0ubuntu1~vivid1)
libreoffice-gnome:amd64 (5.0.1~rc2-0ubuntu1~vivid1)
libreoffice-sdbc-firebird:amd64 (5.0.1~rc2-0ubuntu1~vivid1)
libwps-0.3-3:amd64 (0.3.0-2)
unoconv:amd64 (0.6-6)
inkscape:amd64 (0.91-3ubuntu1)
libreoffice-report-builder-bin:amd64 (5.0.1~rc2-0ubuntu1~vivid1)
libwpd-0.10-10:amd64 (0.10.0-2)
libreoffice-help-en-us:amd64 (5.0.1~rc2-0ubuntu1~vivid1)
libreoffice-ogltrans:amd64 (5.0.1~rc2-0ubuntu1~vivid1)
python3-uno:amd64 (5.0.1~rc2-0ubuntu1~vivid1)
libabw-0.1-1:amd64 (0.1.0-2)
libe-book-0.1-1:amd64 (0.1.1-2)
libreoffice-sdbc-hsqldb:amd64 (5.0.1~rc2-0ubuntu1~vivid1)
libreoffice-gtk:amd64 (5.0.1~rc2-0ubuntu1~vivid1)
mythes-de:amd64 (20120516-2)
libcdr-0.1-1:amd64 (0.1.0-3)
libodfgen-0.1-1:amd64 (0.1.1-2)
mythes-en-us:amd64 (4.2.1-0ubuntu3)
libreoffice-base-drivers:amd64 (5.0.1~rc2-0ubuntu1~vivid1)
libfreehand-0.1-1:amd64 (0.1.0-2)
libreoffice-math:amd64 (5.0.1~rc2-0ubuntu1~vivid1)
libreoffice-calc:amd64 (5.0.1~rc2-0ubuntu1~vivid1)
A.B.
  • 92,125
You could just reinstall the lost one, and type this in the terminal:
sudo apt-get install dpkg gimp compiz
and then it might work fine this way.
Michael
  • 2,597
