What is the function of virtual box and wine ? And if they have the same function which is better?
I got confused in choosing program to load my windows stuff
Pilot6
  • 92,041
Virtualbox allows you to install other operating systems inside Ubuntu. You can install a real Windows this way.
All programs will run in it. But this requires a lot of RAM an CPU power, because a virtual machine can use only part of these resources.
Wine allows you to run some Windows programs in Ubuntu. Not all programs will run well, some will not run at all.
Pilot6
  • 92,041
Wine
Pros: You can run some Windows apps without needing Windows.
Cons: Only some Windows apps will work.
VirtualBox
Pros: You can run virtually any Windows app.
Cons: You need a pretty beefy computer to run VirtualBox effectively, and a full install of Windows.
If the apps you need, run via Wine, then I would say that is the best choice. If not, VirtualBox is a good choice.
If you have a copy of Windows with a valid license and if your hardware is powerful enough, then virtualbox would definitely be the way to go.
However, lacking a copy of Windows with a valid license or lacking sufficient hardware, then wine, playonlinux or crossover (I think that's what it is called) would probably be the better choice
Reference: This post by anewguy at Wine Vs Virtual Box
Ravan
  • 9,567
