I have noticed, that although my "Bluetooth Headset" works perfectly fine, buttons on it, like Previous, Next, Play etc do not.
Why is that?
As of Ubuntu 10.04, uinput module that handles such buttons is not started by default. To fix the situation:
sudo service bluetooth stop sudo modprobe uinputsudo service bluetooth startThat should fix the issue temporarily, until restart. To fix it permanently, run:
echo 'uinput' | sudo tee -a /etc/modules
Vava's answer did not fix the issue for me alone (Ubuntu 20.04), I had to use, in addition, xbindkeys and playerctl https://wiki.archlinux.org/title/Xbindkeys
First, disable/unassign the shortcuts for media play and pause via the shortcut editor.
sudo apt install xbindkeys playerctl
xbindkeys -d > ~/.xbindkeysrc
Open ~/.xbindkeysrc and delete all lines between line 40 and 66 inclusive.
xbindkeys --key
Get the raw keycode (e.g. m:0x0 + c:209). Your headset might toggle between play and pause keycodes, so run xbindkeys --key twice to get code for both play and pause.
Put the following into your ~/.xbindkeysrc with the correct key codes.
"playerctl play-pause"
m:0x0 + c:208t
m:0x0 + c:209
If your headset is already passing XF86Play or some other key (you can use screenkey to check, you can use the following instead as an example
XF86AudioPlay
playerctl play-pause will control "the first available player". Read playerctl -h for more info/options if needed.
Open /etc/X11/Xsession as root. Add the line xbindkeys after the line PROGNAME=Xsession.
Reboot.
My headset now correctly controls Youtube videos.
