I'm trying to install opencv on ubuntu 14.04 embedded Zynq SoC processor
linaro@linaro-nano:~$ sudo apt-get update
Ign http://ports.ubuntu.com trusty InRelease
Ign http://ppa.launchpad.net trusty InRelease
Hit http://ports.ubuntu.com trusty Release.gpg
Hit http://ppa.launchpad.net trusty Release.gpg
Hit http://ports.ubuntu.com trusty/main Sources
Hit http://ppa.launchpad.net trusty/main Sources
Hit http://ports.ubuntu.com trusty/universe Sources
Hit http://ppa.launchpad.net trusty/main armhf Packages
Hit http://ports.ubuntu.com trusty/main armhf Packages
Hit http://ppa.launchpad.net trusty/main Translation-en
Hit http://ports.ubuntu.com trusty/universe armhf Packages
Hit http://ports.ubuntu.com trusty/main Translation-en
Hit http://ports.ubuntu.com trusty/universe Translation-en
Reading package lists... Done
linaro@linaro-nano:~$ sudo apt-get install pkg-config build-essential libopencv-dev
Building dependency tree
build-essential is already the newest version.
pkg-config is already the newest version.
libopencv-dev : Depends: libopencv-objdetect-dev (= 2.4.8+dfsg1-2ubuntu1) but it is not going to be installed
Depends: libopencv-highgui-dev (= 2.4.8+dfsg1-2ubuntu1) but it is not going to be installed
Depends: libopencv-legacy-dev (= 2.4.8+dfsg1-2ubuntu1) but it is not going to be installed
Depends: libopencv-contrib-dev (= 2.4.8+dfsg1-2ubuntu1) but it is not going to be installed
Depends: libopencv-videostab-dev (= 2.4.8+dfsg1-2ubuntu1) but it is not going to be installed
Depends: libopencv-superres-dev (= 2.4.8+dfsg1-2ubuntu1) but it is not going to be installed
Depends: libopencv-ocl-dev (= 2.4.8+dfsg1-2ubuntu1) but it is not going to be installed
Depends: libcv-dev (= 2.4.8+dfsg1-2ubuntu1) but it is not going to be installed
Depends: libhighgui-dev (= 2.4.8+dfsg1-2ubuntu1) but it is not going to be installed
Depends: libcvaux-dev (= 2.4.8+dfsg1-2ubuntu1) but it is not going to be installed
linaro@linaro-nano:~$ sudo apt-get install libopencv-objdetect-dev libopencv-highgui-dev libopencv-legacy-dev libopencv-contrib-dev libopencv-videostab-dev libopencv-superres-dev libcvaux-dev libhighgui-dev libcv-dev libopencv-ocl-dev pkg-config build-essential libopencv-dev
libopencv-highgui-dev : Depends: libgtk2.0-dev but it is not going to be installed
linaro@linaro-nano:~$ sudo apt-get install libgtk2.0-dev libopencv-objdetect-dev libopencv-highgui-dev libopencv-legacy-dev libopencv-contrib-dev libopencv-videostab-dev libopencv-superres-dev libcvaux-dev libhighgui-dev libcv-dev libopencv-ocl-dev pkg-config build-essential libopencv-dev
libgtk2.0-dev : Depends: libpango1.0-dev (>= 1.20) but it is not going to be installed
Depends: libcairo2-dev (>= 1.6.4-6.1) but it is not going to be installed
linaro@linaro-nano:~$ sudo apt-get install libcairo2-dev libpango1.0-dev libgtk2.0-dev libopencv-objdetect-dev libopencv-highgui-dev libopencv-legacy-dev libopencv-contrib-dev libopencv-videostab-dev libopencv-superres-dev libcvaux-dev libhighgui-dev libcv-dev libopencv-ocl-dev pkg-config build-essential libopencv-dev
libcairo2-dev : Depends: libfontconfig1-dev (>= 2.2.95) but it is not going to be installed
Depends: libfreetype6-dev (>= 2.1.10) but it is not going to be installed
libpango1.0-dev : Depends: libfreetype6-dev but it is not going to be installed
Depends: libxft-dev but it is not going to be installed
Depends: libfontconfig1-dev (>= 2.10.91) but it is not going to be installed
linaro@linaro-nano:~$ sudo apt-get install libfontconfig1-dev libxft-dev libfreetype6-dev libfontconfig1-dev libcairo2-dev libpango1.0-dev libgtk2.0-dev libopencv-objdetect-dev libopencv-highgui-dev libopencv-legacy-dev libopencv-contrib-dev libopencv-videostab-dev libopencv-superres-dev libcvaux-dev libhighgui-dev libcv-dev libopencv-ocl-dev pkg-config build-essential libopencv-dev
libfreetype6-dev : Depends: libfreetype6 (= 2.5.2-1ubuntu2) but 2.5.2-1ubuntu2.2 is to be installed
