I am trying to install libfreetype6-dev.
Running sudo apt-get install libfreetype6-dev gives
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies: libfreetype6-dev : Depends: libfreetype-dev (= 2.10.1-2ubuntu0.1) but it is not going to be installed E: Unable to correct problems, you have held broken packages.
I tried forcing the version, as mentioned here, and added fix-broken and f flags, but it still fails to install.
Ceres
  • 109
As the error says, libfreetype-dev needs to be installed as a dependency, trying to install it raised the error
The following packages have unmet dependencies: libfreetype-dev : Depends: libfreetype6 (= 2.10.1-2ubuntu0.1) but 2.10.1-2ubuntu0.20.04ppa1 is to be installed E: Unable to correct problems, you have held broken packages.
So I had to force install libfreetype6=2.10.1-2ubuntu0.1 with
sudo apt get-install libfreetype6=2.10.1-2ubuntu0.1,
after that I could install libfreetype-dev, and then libfreetype6-dev with
sudo apt-get install libfreetype-dev
sudo apt-get install libfreetype6-dev.
Ceres
  • 109
