When I run:
sudo apt-get update
I get this error at the end:
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/trusty/Release Unable to find expected entry 'restricted/source/Sources' in Release file (Wrong sources.list entry or malformed file)
E: Some index files failed to download. They have been ignored, or old ones used instead.
The question How do I remove a malformed line from my sources.list? is similar, but there the error reports Malformed line 91 in But this error does not show any erroneous line number.
I have been trying to solve this issue for the last two hours.
- Verified that the
sources.listhas no errors - Tried this solution and got the same errors.
Finally what worked a few minutes ago was 'selecting the best server' from Synaptic, which finally succeeded in refreshing all the package lists.
But still I am unable to install new softwares. This is a fresh installation of Ubuntu 14.04.3 64-bit from the homepage.
When I run sudo apt-get install libpq-dev, I get this response:
Reading package lists... Done
Building dependency tree
libpq-dev : Depends: libssl-dev but it is not going to be installed
sources.list - stripped out comments
deb http://archive.ubuntu.com/ubuntu trusty main restricted
deb http://archive.ubuntu.com/ubuntu trusty-updates main restricted
deb http://archive.ubuntu.com/ubuntu trusty universe
deb http://archive.ubuntu.com/ubuntu trusty-updates universe
deb http://archive.ubuntu.com/ubuntu trusty-security main restricted
deb http://archive.ubuntu.com/ubuntu trusty-security universe
deb http://archive.canonical.com/ubuntu trusty partner
deb-src http://archive.canonical.com/ubuntu trusty partner
deb http://extras.ubuntu.com/ubuntu trusty main
deb-src http://extras.ubuntu.com/ubuntu trusty main
apt-cache policy libssl-dev
libssl-dev:
Installed: (none)
Candidate: 1.0.1f-1ubuntu2.15
Version table:
1.0.1f-1ubuntu2.15 0
500 http://archive.ubuntu.com/ubuntu/ trusty-updates/main amd64 Packages
500 http://archive.ubuntu.com/ubuntu/ trusty-security/main amd64 Packages
1.0.1f-1ubuntu2 0
500 http://archive.ubuntu.com/ubuntu/ trusty/main amd64 Packages
apt-cache policy libpq-dev
libpq-dev:
Installed: (none)
Candidate: 9.3.9-0ubuntu0.14.04
Version table:
9.3.9-0ubuntu0.14.04 0
9.3.7-0ubuntu0.14.04 0
9.3.4-1 0
