Is there any way to let the Shift, Ctrl and Alt keys behave as toggles under X? I know how one could do it under CLI (for example, by doing this) but found no reference for doing so under X.
Please note that this is not a question on sticky keys, which can be enabled by an accessibility option.
user.dz
  • 49,176
Gödel
  • 1,811
This is implemented on the DE level AFAIK. KDE has the option to Lock Sticky Keys:
With Lock Sticky Keys enabled:
If you press the Shift key twice then press the F key, the computer interprets this as Shift+F. Now if you type a P, the computer interprets this as the letter P (Shift+P). To de-select the Shift key, press it again.
http://docs.kde.org/stable/en/kdebase-workspace/kcontrol/kcmaccess/index.html
Kris Harper
  • 13,705
scottl
  • 2,588
This can be achieved using XKB compatibility component
  1. Check the compatibility variant you are using
    $ setxkbmap -v -query
    Trying to build keymap using the following components:
    keycodes:   evdev+aliases(qwerty)
    types:      complete
    compat:     complete
    symbols:    pc+us(altgr-intl)+us:2+inet(evdev)
    geometry:   pc(pc105)
    rules:      evdev
    model:      pc105
    layout:     us,us
    variant:    altgr-intl,
    $ more /usr/share/X11/xkb/compat/complete
    default xkb_compatibility "complete"  {
        include "basic"
        augment "iso9995"
        augment "mousekeys"
        augment "accessx(full)"
        augment "misc"
        augment "xfree86"
        augment "level5"
        augment "caps(caps_lock)"
  2. Modify misc file, the one which contains the needed modifiers interpretations
    sudo nano /usr/share/X11/xkb/compat/misc
    I have changed Shift_L, Alt_L & Alt_R action from SetMods to LockMods, added new Shift_R, Control_L & Control_R interpretation with LockMods and commented //setMods.clearLocks (not sure if it's needed). Here is the complete file:
    default partial xkb_compatibility "misc"  {
        virtual_modifiers   Alt,Meta,Super,Hyper,ScrollLock;
        // Interpretations for some other useful keys
        interpret Terminate_Server {
            action = Terminate();
        //setMods.clearLocks= True;
        // Sets the "Alt" virtual modifier
        interpret Alt_L+Any     {
            //useModMapMods= level1;
        virtualModifier= Alt;
        action = LockMods(modifiers=modMapMods);
        interpret Alt_L {
        action = LockMods(modifiers=Alt);
        interpret Alt_R+Any     {
        interpret Alt_R {
        // Sets the "Meta" virtual modifier
        interpret Meta_L+Any     {
    //        useModMapMods= level1;
        virtualModifier= Meta;
        action = SetMods(modifiers=modMapMods);
        interpret Meta_L    {
        action = SetMods(modifiers=Meta);
        interpret Meta_R+Any     {
        interpret Meta_R    {
        // Sets the "Super" virtual modifier
        interpret Super_L+Any     {
        virtualModifier= Super;
        interpret Super_L   {
        action = SetMods(modifiers=Super);
        interpret Super_R+Any     {
        interpret Super_R   {
        // Sets the "Hyper" virtual modifier
        interpret Hyper_L+Any     {
        virtualModifier= Hyper;
        interpret Hyper_L   {
        action = SetMods(modifiers=Hyper);
        interpret Hyper_R+Any     {
        interpret Hyper_R   {
        // Sets the "ScrollLock" virtual modifier and
        // makes it actually lock when pressed.  Sets
        // up a map for the scroll lock indicator.
        interpret Scroll_Lock+Any   {
        virtualModifier= ScrollLock;
        include "ledscroll"
        include "misc(assign_shift_left_action)"
    partial xkb_compatibility "assign_shift_left_action"  {
        // Because of the irrevertable modifier mapping in symbols/pc <LFSH> is
        // getting bound to the Lock modifier when using
        // symbols/shift(both_capslock), creating unwanted behaviour.
        // This is a quirk, to circumvent the problem.
        interpret Shift_L {
            action = LockMods(modifiers = Shift);
        interpret Shift_R {
        interpret Control_L {
            action = LockMods(modifiers = Control);
        interpret Control_R {
  3. Compile the change & update the initramfs images
    sudo dpkg-reconfigure xkb-data
    sudo update-initramfs -u -k all
  4. Reboot
References:
user.dz
  • 49,176
Keys in X11 are remapped with xmodmap, but there is no Control_Lock in /usr/include/X11/keysymdef.h
If you have a few keys you could map Control to something like ISO_Next_Group_Lock and define your keys in this group with Control + Key.
I found some info here: https://bbs.archlinux.org/viewtopic.php?id=75771
Kris Harper
  • 13,705
sroecker
  • 2,620
