I use graphics software like GIMP, Inkscape & Blender extensively for my business. But most of them require the use of the Alt key in some way or the other. Come Ubuntu 11.10, I haven't been able to find any way to change the shortcut for window moving/resizing from Alt+LMB/MMB to Super/Meta+LLM/MMB. This option was present in the 'Windows' settings in Gnome2, but it is not present anywhere in Gnome3. And yes, I have tried searching through the Shortcuts tab in Keyboard settings, its not there.
Zanna
  • 72,312
5 Answers5
  1. Install compizconfig-settings-managerInstall compizconfig-settings-manager.
  2. Open CompizConfig Settings Manager and navigate to the Resize Window plugin.
  3. Click the <Super>Button2 button and rebind the shortcut.
Isaiah
  • 60,750
In Ubuntu 13.10 this worked for me:
  1. Open a terminal (Ctrl+Alt+T) and type sudo apt-get install dconf-editor. Enter your password when prompted and after the installation is finished type dconf-editor to open the Configuration Editor.
  2. Now either hit Ctrl+F and use the hereby summoned field to search for mouse-button-modifier or navigate to org.gnome.desktop.wm.preferences and find the same.
  3. Change its value from <Alt> to something else (<Super> will probably work best) and enjoy your improved workflow!
NB: Leaving the field empty will get you stuck in drag-mode, unable to click the "Set to Default" button. You can bring the focus to this button by pressing Tab until a fine orange rim shows up around it. Then press Space and repeat step 3.
Zanna
  • 72,312
魔大农
  • 153
Well, at least for Blender, you don't really need to go all this trouble.
Go to File > User Preferences > Input
In the search field type edge
Voila.
To cut this short story shorter the shortcuts on Blender are
  • Ctrl+Alt+Select Mouse and
  • Shift+Ctrl+Alt+Select Mouse respectively.
Zanna
  • 72,312
Start Kubuntu v20.04 > Window Behavior > Window Actions
SL5net
  • 698
  • 28
-1
Install compizconfig-settings-manager from Software Center. When you have installed (and opened) it, search there for "Unity plug-in" or something similar and click it. Select Switcher and there you can select the buttons which will open the Switcher.
Zanna
  • 72,312
