Similar question have been asked before, but there were no answers. I cannot comment there, nor I have an answer, therefore I don't see other option but to ask again.
I have a USB laser presenter August LP205R that does not work on GNOME Ubuntu 15.04, but works OK on Windows with both PowerPoint & PDF presentations. Here are the outputs asked for in the previous link:
xinput
⎡ Virtual core pointer                      id=2    [master pointer  (3)]
⎜   ↳ Virtual core XTEST pointer                id=4    [slave  pointer  (2)]
⎜   ↳ SynPS/2 Synaptics TouchPad                id=11   [slave  pointer  (2)]
⎜   ↳ RF 2.4G  RF 2.4G                          id=14   [slave  pointer  (2)]
⎣ Virtual core keyboard                     id=3    [master keyboard (2)]
    ↳ Virtual core XTEST keyboard               id=5    [slave  keyboard (3)]
    ↳ Power Button                              id=6    [slave  keyboard (3)]
    ↳ Video Bus                                 id=7    [slave  keyboard (3)]
    ↳ Power Button                              id=8    [slave  keyboard (3)]
    ↳ Laptop_Integrated_Webcam_HD               id=9    [slave  keyboard (3)]
    ↳ AT Translated Set 2 keyboard              id=10   [slave  keyboard (3)]
    ↳ Dell WMI hotkeys                          id=12   [slave  keyboard (3)]
    ↳ RF 2.4G  RF 2.4G                          id=13   [slave  keyboard (3)]
lsusb
Bus 001 Device 004: ID 0bda:0129 Realtek Semiconductor Corp. RTS5129 Card Reader Controller
Bus 001 Device 003: ID 0c45:64ad Microdia
Bus 001 Device 005: ID 1d57:83ed Xenta
Bus 001 Device 002: ID 8087:07e6 Intel Corp.
xev gives output only on Start/End slideshow button:
KeyPress event, serial 33, synthetic NO, window 0x3000001,
    root 0xac, subw 0x0, time 14518987, (642,556), root:(643,609),
    state 0x10, keycode 50 (keysym 0xffe1, Shift_L), same_screen YES,
    XLookupString gives 0 bytes:
    XmbLookupString gives 0 bytes:
    XFilterEvent returns: False
KeyRelease event, serial 36, synthetic NO, window 0x3000001,
    root 0xac, subw 0x0, time 14519138, (642,556), root:(643,609),
    state 0x11, keycode 50 (keysym 0xffe1, Shift_L), same_screen YES,
I even tried the getscancodes and dmesg | tail recommended previously:
~/Downloads$ tar -xvzf getscancodes-1.0.tar.gz
getscancodes/
getscancodes/getscancodes.c
getscancodes/Makefile
getscancodes/getscancodes.o
~/Downloads$ cd getscancodes/
~/Downloads/getscancodes$ make
gcc -O2 -Wall   -c -o getscancodes.o getscancodes.c
gcc -o  getscancodes getscancodes.o
~/Downloads/getscancodes$ sudo ./getscancodes /dev/input/event16
[sudo] password for :
getscancodes: No such file or directory
~/Downloads/getscancodes$ cd ..
~/Downloads$ sudo ./getscancodes /dev/input/event16
sudo: ./getscancodes: command not found
~/Downloads/getscancodes$ dmesg | tail
[ 8630.569019] usb 1-1.2: New USB device found, idVendor=1d57, idProduct=83ed
[ 8630.569043] usb 1-1.2: New USB device strings: Mfr=1, Product=1, SerialNumber=0
[ 8630.569059] usb 1-1.2: Product: RF 2.4G
[ 8630.569073] usb 1-1.2: Manufacturer: RF 2.4G
[ 8631.425965] usbcore: registered new interface driver usbhid
[ 8631.425982] usbhid: USB HID core driver
[ 8631.720489] input: RF 2.4G  RF 2.4G  as /devices/pci0000:00/0000:00:1d.0/usb1/1-1/1-1.2/1-1.2:1.0/0003:1D57:83ED.0001/input/input11
[ 8631.776680] hid-generic 0003:1D57:83ED.0001: input,hidraw0: USB HID v1.10 Keyboard [RF 2.4G  RF 2.4G ] on usb-0000:00:1d.0-1.2/input0
[ 8631.778126] input: RF 2.4G  RF 2.4G  as /devices/pci0000:00/0000:00:1d.0/usb1/1-1/1-1.2/1-1.2:1.1/0003:1D57:83ED.0002/input/input12
[ 8631.833351] hid-generic 0003:1D57:83ED.0002: input,hidraw1: USB HID v1.10 Mouse [RF 2.4G  RF 2.4G ] on usb-0000:00:1d.0-1.2/input1
I was wondering if somebody could help me figure out if & how should I update or make a new *-keyboard.hwdb file from the data above, as mentioned here:
Thanks in advance! :)
  • Looking in web for similar device point me that your device is 1d57:83ed Xenta and it create two input devices (a mouse and a keyboard) labeled as RF 2.4G RF 2.4G with id=14 & id=13 from your commands output.
  • getscancodes was already created in ~/Downloads/getscancodes folder but /dev/input/event16 is not the corresponding event device file. You can find related event file using:
    xinput --list-props 14
    xinput --list-props 13
    Than run ./getscancodes /dev/input/eventXX for both event files and try all keys.
  • If getscancodes didn't work, there a standard tool from Ubuntu repository. Give it a try:
    sudo apt-get install evtest
    sudo evtest
  • The method explained in How do I change the keymap of a single device (Logitech presenter)? is outdated.
    So follow Xubuntu - Logitech presenter works only partialy which have same instructions mentioned as comment/header in /lib/udev/hwdb.d/60-keyboard.hwdb
user.dz
  • 49,176
