I would like to use a Logitech R400 pointer with my Lenovo T440s running on Ubuntu 14.04 64bit. There is a problem with the keys so that forward and backward buttons result in jumping at 1st or last slide respectively.
So I followed the instructions in this previous post (Xubuntu - Logitech presenter works only partialy) and tried to figure out the scancodes (http://derickrethans.nl/logitech-r400-take2.html).
  • It didn't work as the device is not properly recognized. Instead of recieving something like:
    lsusb
    Bus 004 Device 003: ID 046d:c52d Logitech, Inc.
    I get:
    Bus 002 Device 017: ID 0e00:0111
  • Instead of /dev/input/by-id containing
    usb-Logitech_USB_Receiver-event-kbd
    I have:
    usb-MOUSE_USB_MOUSE-event-kbd
    usb-MOUSE_USB_MOUSE-event-if01-event-mouse
    usb-MOUSE_USB_MOUSE-event-if01-mouse
Accordingly, the device is not recognized as a R400 so that modification of /lib/udev/hwdb.d/60-keyboard.hwdb or newly created /etc/udev/hwdb.d/70-keyboard.hwdb have no effect.
Does anybody know why the R400 is not properly recognized and how to correct this?
Thank you for your time considering my issue!
Update:
According to xinput, the pointer device is:
Virtual core pointer -> MOUSE USB MOUSE id=17 Virtual core keyboard -> MOUSE USB MOUSE id=11
  • Output of ./getscancodes /dev/input/event17:
    Input driver version is 1.0.1
    Input device ID: bus 0x3 vendor 0xe00 product 0x111 version 0x110
    Input device name: "MOUSE USB MOUSE" ^[OH^[OF^[^[[15;2~b
  • Output of ./getscancodes /dev/input/event11:
    Input device ID: bus 0x0 vendor 0x0 product 0x0 version 0x0
    Input device name: "HDA Intel HDMI HDMI/DP,pcm=8" ^[OH^[OF^[^[[15;2~b
  • However, id=11 says in xinput --list-props 11 that it is related to /dev/input/event9. scancodes of event9 are:
    458827 (0x7004b) ^[OH458827 (0x7004b) 458830 (0x7004e) ^[OF458830 (0x7004e) 458981 (0x700e5) 458814 (0x7003e) ^[[15;2~458981 (0x700e5) 458814 (0x7003e) 458757 (0x70005) b458757 (0x70005)
    These partially correspond to scancodes given link (Tweaking the Logitech R400 presenter tool on Linux)
Update:
Id is changing from time to time, so today the device is id=17.
Scan codes for this device are as follows:
left button -> 458827 (0x7004b)
right button -> 458830 (0x7004e)
start presentation -> 458793 (0x70029)
blank screen -> 458793 (0x70029)
Patrick
  • 31
  1. Create new hwdb file:
    sudo nano /etc/udev/hwdb.d/70-keyboard.hwdb
  2. Put this in it:
    keyboard:usb:v0E00p0111d*dc*dsc*dp*ic*isc*ip*in00*
    KEYBOARD_KEY_070029=f5
    KEYBOARD_KEY_07004b=left
    KEYBOARD_KEY_07004e=right
  3. Ctrl+O to save then Ctrl+X to exit.
  4. Update udev database
    sudo udevadm hwdb --update
  5. Reboot
user.dz
  • 49,176
I know the Question is quiet old, but since im still using the presenter mentioned here I'll add my solution. I had the same problem on Archlinux. It was working for me this way.
Create custom config file:
Put this into the file and save (coorect device ID and my scancodes):
# R400
evdev:input:v0E00p0111*
 KEYBOARD_KEY_700e5=f5  # presentation button
 KEYBOARD_KEY_7003e=f5  # presentation button
 KEYBOARD_KEY_70005=f8  # monitor button
 KEYBOARD_KEY_7004b=left
 KEYBOARD_KEY_7004e=right
you might have to adjust the scancodes, since the start presentation scancode seems to differ from mine (and it should show two scancodes for the presentation button, you have to add them both).
run
sudo systemd-hwdb update
and
sudo udevadm trigger
David
