I have checked my installed kernels
www-data@May:~$ dpkg -l linux-image-\* | grep ^ii
ii  linux-image-3.13.0-57-generic       3.13.0-57.95                        amd64        Linux kernel image for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-3.13.0-61-generic       3.13.0-61.100                       amd64        Linux kernel image for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-extra-3.13.0-57-generic 3.13.0-57.95                        amd64        Linux kernel extra modules for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-extra-3.13.0-61-generic 3.13.0-61.100                       amd64        Linux kernel extra modules for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-generic                 3.13.0.61.68                        amd64        Generic Linux kernel image
I have checked my boot
www-data@May:~$ ls /boot/
System.map-3.13.0-57-generic  grub              memtest86+.elf
System.map-3.13.0-61-generic  initrd.img-3.13.0-55-generic  memtest86+_multiboot.bin
abi-3.13.0-57-generic         initrd.img-3.13.0-57-generic  vmlinuz-3.13.0-57-generic
abi-3.13.0-61-generic         initrd.img-3.13.0-61-generic  vmlinuz-3.13.0-61-generic
config-3.13.0-57-generic      lost+found
config-3.13.0-61-generic      memtest86+.bin
The above is what I have AFTER I have run sudo apt-get autoremove
I continue to have > 90% of usage of boot.
Please advise.
Kim Stacks
  • 1,076
There are many other kernel-specific packages. You should sudo apt-get remove the obsolete ones. Here is how I found my obsolete packages:
# first, use the current kernel version (DO NOT REMOVE YOUR CURRENT KERNEL)
# to get a list of installed packages with the same version number.
dpkg -l | fgrep $(uname -r | sed -e 's/-generic//') | egrep '^ii'
# Then, inspecting the output, and manually selecting non-version
# substrings, construct a regular expression for egrep. I got:
dpkg -l | egrep 'linux-tools-|linux-source-|linux-libc-dev|linux-image-|linux-headers-'| egrep -v $(uname -r | sed -e 's/-generic//')
This produces a list of candidates for sudo apt-get remove. Eliminate from this list your current kernel and all of its like-versioned kin (I did that in the last egrep) AND the previous N versions. Start with N=3, use N=2 with caution, and try to avoid the N=1 case.
waltinator
  • 37,856
