$ sudo apt-get install libgimp2.0-dev
Reading package lists... Done
Building dependency tree
libgimp2.0-dev : Depends: libgtk2.0-dev (>= 2.12.5) but it is not going to be installed
It says broken packages, I am not a techy so do not understand the jargons
"You must install libgimp2.0-dev and libpcre3-dev packages in order to have
the full set of libraries and dependences to compile BIMP (names can differ depending on the distro)."
in the installation document I have searched for all answers possible given online, but none has been able to resolve my issue of installing bimp
If you could advice the possible steps to install bimp would be of help
