Possible Duplicate:
Performance being really choppy with ATI drivers
I have Ubuntu 11.10 64bit installed on a machine with an AMD A6-3400M CPU, and a Radeon HD 6520G card. For some reason all compiz animations are very jittery and unpleasant to look at.
I have the ATI FGLRX driver installed but when I try to install the version with post-release updates from jockey it says installation failed.
I have tried downloading compiz config, and setting the refresh rate to 60hz (from 50hz, I read online that this helps) but it always changes back to 50, even after I check off not to detect the refresh rate.
If need be, I can post the jockey log.
Perhaps the issue is with 64 bit ubuntu, but if I install 32 bit, will it be able to address all 6GB of my ram? I know windows 32 bit can't.
Thanks in advance.
