I tried to install ChessX using Ubuntu Software Center. But it shows error. Hence,How to install it? Or Any alternate Chess Game for Ubuntu 14.04?
Asked
Active
Viewed 6,398 times
The problem here, based on your terminal output is:
E: Unable to correct problems, you have held broken packages
To fix this, open terminal and run
sudo apt-get -f install && apt-get update
Then try the install again
sudo apt-get install chessx
George Udosen
- 37,534
Mark Kirby
- 18,949
- 19
- 79
- 116
First make sure that Universe Repositories are enabled.
Once that is done, just press Ctrl+Alt+T on your keyboard to open Terminal. When it opens, run the command(s) below:
sudo apt-get update && sudo apt-get install chessx
