16
If i try to open any of partition, I get error message in a box.
Error mounting /dev/sda8 at /media/viratraaz/Documents: Command-line `mount -t "ntfs" -o "uhelper=udisks2,nodev,nosuid,uid=1000,gid=1000,dmask=0077,fmask=0177" "/dev/sda8" "/media/viratraaz/Documents"' exited with non-zero exit status 14: The disk contains an unclean file system (0, 0).
Metadata kept in Windows cache, refused to mount.
Failed to mount '/dev/sda8': Operation not permitted
The NTFS partition is in an unsafe state. Please resume and shutdown
Windows fully (no hibernation or fast restarting), or mount the volume
read-only with the 'ro' mount option.
hg8
  • 13,582
Virat Raaz
  • 163
You need to disable Windows fast start-up option.
Open Control Panel -> Energy Settings and select Change what the power buttons do.
Choose Change settings that are currently unavailable, scroll down and uncheck
Turn on fast start-up (recommended).
Restart the computer and you won't have this error anymore.
See here for more informations about Windows Fast Boot.
hg8
  • 13,582
13
It happens because of the partial hibernation of Windows (From Windows 8). I hope you are trying to open a drive from your dual booted system which is shutdowned from Windows last time.
A quick and dirty way to fix this problem is, executing the following command on each drives:
sudo ntfsfix /dev/sdxx
where xx is device and partition letter and number ie: /dev/sda1
For more details: WORKAROUNDS FOR NOT BEING ABLE TO MOUNT THE WINDOWS 8 PARTITION IN LINUX DUE TO HIBERNATION
Gobinath
  • 3,392
