14
I am using Ubuntu 11.10 (Oneiric Ocelot), with a "Intel Corporation 82801G (ICH7 Family) AC'97 Audio Controller (rev 01)" sound card.
When I plug headphones into the front headphone port, the sound that comes out is far too loud to listen to - and has to be turned down to about 5%. Anything above that is distorted and deafening.
I have played around in Alsamixer, and whilst a decent level can be achieved (through changing three separate sliders), this is not ideal for changing the volume on my parents' computer. And using the standard volume control overrides all of that anyway.
Farran
  • 161
5 Answers5
13
I experienced the same problem and I have written a post about the solution I found here. Basically what I did was this:
Open the file /etc/pulse/default.pa by typing the following in a terminal:
gksudo gedit /etc/pulse/default.pa
Change the line that says
load-module module-udev-detect
into
load-module module-udev-detect ignore_dB=1
Save and close the file.
Restart pulseaudio by typing the following in a terminal:
pulseaudio -k
Now open alsamixer:
alsamixer
Then lower the PCM volume to a decent level (I set mine to about 50 %). After doing this, changing the volume using the volume keys or volume slider won't reset the settings for PCM in alsamixer and will let you keep the lowest threshold of the volume a as low as you'd like. This will also keep the volume intervals smaller. The only negative effect is that you won't get as much sound out of your speakers without headphones unless you change back the PCM settings in alsamixer again.
I can't guarantee that this will work on your system, but it did work nicely on mine.
dragly
  • 320
10
None of the solutions worked for me.
Here's what got my issue solved:
Edit /usr/share/pulseaudio/alsa-mixer/paths/analog-output.conf.common
sudo vim /usr/share/pulseaudio/alsa-mixer/paths/analog-output.conf.common
Change:
[Element PCM]
switch = mute
volume = merge
override-map.1 = all
override-map.2 = all-left,all-right
To:
[Element PCM]
switch = mute
volume = ignore
volume-limit = 0.01
Adjust volume-limit so that it fits your headphones volume range. In my case 0.01 was good.
Restart pulseaudio: pulseaudio -k or reboot sudo reboot
Full credits to this site. https://chrisjean.com/fix-for-usb-audio-is-too-loud-and-mutes-at-low-volume-in-ubuntu/
UPDATE:
The above solution overwrites all sound outputs. Hence, lowering your speakers volume limit too.
In order to lower only headphones max, set the above config into the [Option Analog Output:Headphones] section (same analog-output.conf.common).
Before:
name = output-headphones
priority = 9
After:
priority = 9
volume = ignore
volume-limit = 0.0
Gerard Rovira
  • 1,263
None of the above works for me even after searching solution for hours.
For me, I just had to change my sound card, and there, I find it exactly what I want.
The steps which I followed were:
  1. Type alsamixer in terminal and hit enter
  2. Press F6 and choose your sound card (I selected USB PnP Sound Device as I was using USB headphones) and press Enter
  3. Here you'll find the volume bars, adjust the one for your USB headphone so it is not too loud.
Sufian
  • 197
I solved this using sound settings in system settings. On the bottom of the screen, to the left of the "Test Speakers" button is a drop-down labeled "Profile:". I changed it to "High Fidelity Playback (A2DP Sink)" from "Headset Head Unit (HSP/HFP)". And now I can turn the volume down more.
Editing /usr/share/pulseaudio/alsa-mixer/paths/analog-output.conf.common and /etc/pulse/default.pa did not work for me, as some other answers suggested. My problem remained after changing these configs.
The original problem I was experiencing: the sound in my bluetooth headphones would sound bearably quiet but then within a second of playing a video it would gradually increase. This was at the lowest system volume setting - one more keyboard button press to lower the volume would mute the headphones.
Nmath
  • 12,664
With most soundcards there are different mixer channels which amplify themselves. You can try to turn down the headphone output so that you can regulate the volume with the master mixer more accurate. It may be, that you have to install the pavucontrol package by typing sudo apt-get install pavucontrol. At least I hope that the gnome3-developers kept this options in their sound-setting tools ;)
Ewald
  • 354
