84
Does anybody know of a ppa or source I can get a subverison 1.7 deb?
It was just released yesterday so I'm sure something will show up eventually. However I figure this will be a good place to post when something is released.
Jorge Castro
  • 73,717
Ryu
  • 943
6 Answers6
62
As of Ubuntu 12.10, subversion 1.7 is available as part of the distribution. Subversion can be installed using apt-get.
sudo apt-get install subversion
For earlier versions of Ubuntu, there is a ppa available at subversion-1.7. The repository can be added as follows:
sudo apt-add-repository ppa:dominik-stadler/subversion-1.7
To get the latest version of subversion update and upgrade the repository.
sudo apt-get update
sudo apt-get upgrade
I needed to also do a dist-upgrade.
sudo apt-get dist-upgrade
I'm assuming that you already have subversion installed, if not:
elias
  • 1,149
44
There's also a ppa supported directly by the subversion team: "Subversion" team.
You should be able to add the ppa with the following command:
sudo apt-add-repository ppa:svn/ppa
The apt-add-repository command is provided by the python-software-properties package, so make sure to install it first.
Note: RabbitVCS seems to have a problem with subversion 1.7: Rabbitvcs does not mark as versioned subfodlers/files in svn 1.7. This is fixed in the trunk but hasn't (yet) been pushed to a build.
14
The Wandisco script actually install a new repository which contains the .deb file for installing SVN 1.7.
Almost the same can be accomplish by executing the following commands:
sudo add-apt-repository 'deb http://opensource.wandisco.com/ubuntu lucid svn17'
sudo wget -q http://opensource.wandisco.com/wandisco-debian.gpg -O- | sudo apt-key add -
sudo apt-get update
Fernando
  • 348
When use Trac You may notice a problem after upgrading Your Subversion using WANdisco repository. Its symptom is a message in Trac site:
Warning: Can't synchronize with repository "(default)" (Unsupported version control system "svn": No module named svn). Look in the Trac log for more information.
This package binds svn to python2.6 and Ubuntu 12.04 has python2.7. Here is a script which solved the problem on my side:
mkdir /usr/lib/python2.7/dist-packages/libsvn
for f in /usr/lib/pyshared/python2.6/libsvn/*; do ln -s $f /usr/lib/python2.7/dist-packages/libsvn/; done
for f in /usr/share/pyshared/libsvn/*; do ln -s $f /usr/lib/python2.7/dist-packages/libsvn/; done
mkdir /usr/lib/python2.7/dist-packages/svn
for f in /usr/share/pyshared/svn/*; do ln -s $f /usr/lib/python2.7/dist-packages/svn/; done
mkdir /usr/lib/pyshared/python2.7/libsvn
for f in /usr/lib/pyshared/python2.6/libsvn/*; do ln -s $f /usr/lib/pyshared/python2.7/libsvn/; done
Eliah Kagan
  • 119,640
I've used wandisco binaries with apt sources as Fernando described, but now that next Ubuntu version has official binaries updated to 1.7 I wanted to use those while sticking with 12.04 LTS.
Added the following sources to a new file /etc/apt/sources.list.d/svn17.list:
deb http://archive.ubuntu.com/ubuntu/ quantal main universe
deb-src http://archive.ubuntu.com/ubuntu/ quantal main universe
And then according to advice on https://help.ubuntu.com/community/PinningHowto an /etc/apt/apt.conf.d/90svn17:
APT::Default-Release "precise";
Then installed using
sudo apt-get install -V subversion -t quantal
Not sure if these new filenames follow the proper conventions but it works. Tried pinning config first but with no luck. With "-t quantal" pinning wasn't needed.
solsson
  • 186
Don't believe theres any public .deb available yet. You can try this script to install 1.7 from WANdisco
svn1.7_ubuntu_wandisco.sh
#!/bin/bash +x
# WANdisco Subversion Installer V0.1
# opensource@wandisco.com
echo WANdisco Subversion Installer v0.1 for Ubuntu 9.10, 10.04, 10.10
echo Please report problems and bugs to opensource@wandisco.com
echo
echo Gathering some information about your system...
MINVERSION='1'
SVNVER='1.7.0'
ARCH=`uname -m`
SVNSTATUS=`dpkg -l|grep " libsvn1 " | awk '{print $1}'`
#functions
check_is_root ()
    if [[ $EUID -ne 0 ]]; then
        echo "This script must be run as root" 1>&2
        exit 1
    fi
svn_remove_old ()
    echo Removing old packages...
    apt-get -y remove libsvn1 subversion libapache2-svn libsvn-dev libsvn-doc libsvn-perl subversion-tools
add_repo_config ()
        echo Adding repository configuration to /etc/apt/sources.list.d/
    if [ -f /etc/apt/sources.list.d/WANdisco.list ]; then
        rm /etc/apt/sources.list.d/WANdisco.list
    fi
    echo "Installing Apt repo...."
    echo "# WANdisco Open Source Repo" > /etc/apt/sources.list.d/WANdisco.list
    echo "deb http://opensource.wandisco.com/ubuntu lucid svn17" >> /etc/apt/sources.list.d/WANdisco.list
        echo "Importing GPG key"
        wget http://opensource.wandisco.com/wandisco-debian.gpg -O /tmp/wandisco-debian.gpg &>/dev/null
        apt-key add /tmp/wandisco-debian.gpg
        rm -rf /tmp/wandisco-debian.gpg
        apt-get update
install_svn ()
        echo Checking to see if you already have Subversion installed via dpkg...
        if [ "$SVNSTATUS" == "ii" ]; then
        echo
            echo Subversion is already installed on the system.
            echo Do you wish to replace the version of subversion currently installed with the WANdisco version?
        echo This action will remove the previous version from your system.
        echo -n "[y/N]: "
        read svn_install_confirm
        if [ "$svn_install_confirm" == "y" -o "$svn_install_confirm" == "Y" ]; then
            svn_remove_old
            add_repo_config
            echo
            echo Installing Subversion $SVNVER-$MINVERSION
            echo
            apt-get -y --force-yes install subversion libsvn-perl subversion-tools
            echo -n "Would you like to install apache and the apache SVN modules? [y/N] "
            read dav_svn_confirm
            if [ "$dav_svn_confirm" == "y" -o "$dav_svn_confirm" == "Y" ]; then
                echo Installing apache and subversion modules
                apt-get -y --force-yes install apache2 libapache2-svn
                echo -n "Installation complete. Restart apache? [y/N] "
                read apache_restart_confirm
                if [ $apache_restart_confirm == "y" -o $apache_restart_confirm == "Y" ]; then
                    /etc/init.d/apache2 restart
                fi
            fi
            else
            echo "Install Cancelled"
            exit 1
            fi
    else
        # Install SVN
        echo "Subversion is not currently installed"
        echo -n "Starting installation, are you sure you wish to continue? [y/N] "
            add_repo_config
                        echo
                        echo
                                apt-get -y --force-yes install apache2 libapache2-svn libsvn-dev
                                fi
                        fi
                else
                        exit 1
                fi
        fi
install_32 ()
        echo Installing for $ARCH
    install_svn
install_64 ()
    install_svn
#Main
check_is_root
echo Checking your system architecture.
if [ "$ARCH" == "i686" -o "$ARCH" == "i386" ]; then
    install_32
elif [ "$ARCH" == "x86_64" ];
then
    install_64
else
    echo Unsupported platform: $ARCH
    exit 1
fi
Chelmite
  • 1,203
  • 26
