Is there an easy way to modify key- and mouse-bindings for GNOME shell? The gnome-tweak-tool is far from complete regarding these issues and the system settings doesn't include any such options. I guess there is always the possibility of opening the [gd]conf-editor. If that is our final resort for now what key patterns are involved then?
- 733
To change the keyboard bindings, find the keyboard section in the system settings application. Under the shortcuts tab, find the shortcut that's called something like "Go into Overview Mode." Then you can change it to whatever you want.
To disable hot corner, see this question.
All keyboard shortcuts are configured via system settings/keyboard/shortcuts. Overlay mode can be activated with keybinding "show main menu". There're no mouse-bindings.
Under the hood.
Standard keyboard shortcuts are stored at:
gconf:///apps/metacity/global_keybindings
gconf:///apps/metacity/window_keybindings
Modifier to manipulate windows (drag, popup menu) is at:
gconf:///apps/metacity/general/mouse_button_modifier
Shortcuts to launch browser/email/etc at:
dconf:///org/gnome/settings-daemon/plugins/media-keys
Key to enter overview mode is at:
gconf:///apps/mutter/general/overlay_key
The option value is keysym (as given in xkb-config or ~/.Xmodmap), you may put "Menu" here to use menu-key to launch overview. When assigned to other keys it may behave weird.
- 170
You can find all the keybindings used by Gnome Shell at the dconf location
org.gnome.desktop.wm.keybindings
- 6,340
