Possible Duplicate:
How to customize live Ubuntu CD?
I want to customize Ubuntu 10.04, below is the list of things which I want to do:
  1. Install applications that I want.
  2. Change OpenOffice version, Evolution and Firefox version.
How do I do that?
Here are pre-existing questions/answers on the site.
Using a PPA to install a version of a program other than the version in the Softeware Centre
How to install software in Ubuntu
Your question has many answer but I think this is easier to do.
If you don't like the software center (like me) you can simply install the programs via a terminal with the command sudo apt-get install PackageName
Like: sudo apt-get install chromium-browser
Then I simple suggest that you run your scripts. The scripts should simply set up ubuntu the way you want. Install any programs you want and/or set up the system with like; power management, system theme, user background etc.
Good luck and it's always easier to have post-install scripts if you would need to re-install Ubuntu or upgrade it.
Alvar
  • 17,038
-1
I just use remastersys. It just works.
Go here for tips on how to use it http://www.psychocats.net/ubuntu/remastersys
Add deb http://www.geekconnection.org/remastersys/repository karmic/
to your sources Yes, the karmic part is fine, as its for grub2 based ubuntu
duffydack
  • 7,584
