Good evening,
I'm running the lastest ubuntu server edition (i like the: apt-get update/upgrade ; command... a lot) and i need grub to boot only the 1st Ubuntu Server Image (every time).
The grub menu displays: 2 server images and 1 memory tests and 1 extra os from a second attached hdd
These 4 can be found listed in /boot/grub/grub.cfg (i m thinking of deleting the other entries but i ve read that the .cfg file is generated automatically if i add/remove kernel)
Can i set a GRUB_SAVEDEFAULT=true command in the /etc/default/grub ? https://help.ubuntu.com/community/Grub2#Reinstalling%20GRUB2 Or does that not apply to my configuration ?
PS. I think grub pops up because i have often power losses, but i still want grub to load the ubuntu OS... since it s sole purpose is to be a server and local access is limited.
You should never edit your /boot/grub/grub.cfg file - this is always regenerated when a new kernel is downloaded and installed.
If your Ubuntu OS is always the first in the list then the GRUB_DEFAULT=0 in /etc/default/grub is sufficient for this to be the first OS to be booted on a restart.
If your Ubuntu OS is not the first then you can set the GRUB_DEFAULT value to be equal to the menu entry value for Ubuntu OS - see the linked answer below on an example of how to find the OS value and how to add it to Grub.
Linked Question:
  1. How do I set Windows to boot as the default in the boot loader?
fossfreedom
  • 174,526
Here is a link that will help you:
Grub 2 Guide
If your system had a Graphical User Interface then I would recommend Grub Customizer. Here is a link for completeness:
Grub Customizer for easy editing of Grub
Regards.
