13
Ubuntu Server 12.04 is installed on my desktop system (in text-mode, no X-Window is available) and I have no wired Ethernet connected, just wireless network is available. I use TP-Link TL-WN723N USB wireless adapter to connect to wireless network.
At first, tried to use iwconfig to connect, but found that it could not be used to connect to a WPA2 secured network! At fisrt, iwconfig shows:
lo        no wireless extensions.
eth0      no wireless extensions.
wlan0     IEEE 802.11bgn  ESSID:off/any
          Mode:Managed  Access Point: Not-Associated   Tx-Power=20 dBm
          Retry  long limit:7   RTS thr=2347 B   Fragment thr:off
          Power Management:off
and sudo iwlist wlan0 scanning shows:
wlan0   Interface doesn't support scanning : Network is down
after running sudo ifconfig wlan0 up, sudo iwlist wlan0 scanning shows:
wlan0     Scan completed :
          Cell 01 - Address: OO:OO:OO:OO:OO:OO
                    Channel:1
                    Frequency:2.412 GHz (Channel 1)
                    Quality=66/70  Signal level=-44 dBm
                    Encryption key:on
                    ESSID:"MYESSID12345"
                    Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 6 Mb/s
                              9 Mb/s; 12 Mb/s; 18 Mb/s
                    Bit Rates:24 Mb/s; 36 Mb/s; 48 Mb/s; 54 Mb/s
                    Mode:Master
                    Extra:tsf=0000000789abcdef
                    Extra: Last beacon: 32ms ago
                    IE: Unknown: 000123456789ABCEDF0123456789
                    IE: Unknown: 0123456789ABCDEF0123
                    IE: Unknown: 012345
                    IE: Unknown: ABCEDF
                    IE: IEEE 802.11i/WPA2 Version 1
                        Group Cipher : TKIP
                        Pairwise Ciphers (1) : TKIP
                        Authentication Suites (1) : PSK
I installed wpasupplicant to connect to wireless network secured with WPA2. But there are some problems using this package:
I tried following instructions in This answer
wpa_passphrase 'MYESSID12345' 'MYPASSWORD$1234567' > CONFIG_FILE
after above command, I edited CONFIG_FILE (/etc/wpa_supplicant/wpa_supplicant.conf) so it contains:
network={
    ssid="MYESSID12345"
    scan_ssid=1
    key_mgmt=WPA-PSK
    psk="MYPASSWORD$1234567"
    proto=RSN WPA
    pairwise=CCMP TKIP
    group=CCMP TKIP
    #psk=1234567890abcdef1234567890abcdef1234567890abcedf1234567890abcdef
Next i run wpa_supplicant -iwlan0 -c/etc/wpa_supplicant.conf -Dwext -dd. The result is following errors on stderr:
ioctl[SIOCSIWENCODEEXT]: Invalid argument
and stdout is:
Initializing interface 'wlan0' conf '/etc/wpa_supplicant/wpa_supplicant.conf' driver 'wext' ctrl_interface 'N/A' bridge 'N/A'
Configuration file '/etc/wpa_supplicant/wpa_supplicant.conf' -> '/etc/wpa_supplicant/wpa_supplicant.conf'
Reading configuration file '/etc/wpa_supplicant/wpa_supplicant.conf'
Line: 1 - start of a new network block
ssid - hexdump_ascii(len=12):
     01 23 45 67 89 ab cd ef 01 23 45 67               MYESSID12345
scan_ssid=1 (0x1)
key_mgmt: 0x2
PSK (ASCII passphrase) - hexdump_ascii(len=18): [REMOVED]
proto: 0x3
pairwise: 0x18
group: 0x18
PSK (from passphrase) - hexdump(len=32): [REMOVED]
Priority group 0
   id=0 ssid='MYESSID12345'
WEXT: cfg80211-based driver detected
SIOCGIWRANGE: WE(compiled)=22 WE(source)=21 enc_capa=0xf
  capabilities: key_mgmt 0xf enc 0xf flags 0x0
netlink: Operstate: linkmode=1, operstate=5
Own MAC address: mm:mm:mm:mm:mm:mm
wpa_driver_wext_set_key: alg=0 key_idx=0 set_tx=0 seq_len=0 key_len=0
wpa_driver_wext_set_key: alg=0 key_idx=1 set_tx=0 seq_len=0 key_len=0
wpa_driver_wext_set_key: alg=0 key_idx=2 set_tx=0 seq_len=0 key_len=0
wpa_driver_wext_set_key: alg=0 key_idx=3 set_tx=0 seq_len=0 key_len=0
wpa_driver_wext_set_key: alg=0 key_idx=4 set_tx=0 seq_len=0 key_len=0
Driver did not support SIOCSIWENCODEEXT
wpa_driver_wext_set_key: alg=0 key_idx=5 set_tx=0 seq_len=0 key_len=0
wpa_driver_wext_set_countermeasures
RSN: flushing PMKID list in the driver
Setting scan request: 0 sec 100000 usec
WPS: UUID based on MAC address - hexdump(len=16): 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef
EAPOL: SUPP_PAE entering state DISCONNECTED
EAPOL: Supplicant port status: Unauthorized
EAPOL: KEY_RX entering state NO_KEY_RECEIVE
EAPOL: SUPP_BE entering state INITIALIZE
EAP: EAP entering state DISABLED
Added interface wlan0
RTM_NEWLINK: operstate=0 ifi_flags=0x1003 ([UP])
RTM_NEWLINK, IFLA_IFNAME: Interface 'wlan0' added
Wireless event: cmd=0x8b06 len=8
Wireless event: cmd=0x8b1a len=8
State: DISCONNECTED -> SCANNING
Scan SSID - hexdump_ascii(len=12):
Starting AP scan for specific SSID(s)
Scan requested (ret=0) - scan timeout 5 seconds
Wireless event: cmd=0x8b19 len=8
Received 656 bytes of scan results (2 BSSes)
BSS: Start scan result update 1
BSS: Add new id 0 BSSID OO:OO:OO:OO:OO:OO SSID 'MYESSID12345'
BSS: Add new id 1 BSSID 11:11:11:11:11:11 SSID 'OTHER1'
New scan results available
Selecting BSS from priority group 0
Try to find WPA-enabled AP
0: OO:OO:OO:OO:OO:OO ssid='MYESSID12345' wpa_ie_len=0 rsn_ie_len=20 caps=0x11
   selected based on RSN IE
   selected WPA AP OO:OO:OO:OO:OO:OO ssid='MYESSID12345'
Request association: reassociate: 0  selected: OO:OO:OO:OO:OO:OO  bssid: 00:00:00:00:00:00  pending: 00:00:00:00:00:00  wpa_state: SCANNING
Trying to associate with OO:OO:OO:OO:OO:OO (SSID='MYESSID12345' freq=2412 MHz)
FT: Stored MDIE and FTIE from (Re)Association Response - hexdump(len=0):
Cancelling scan request
WPA: clearing own WPA/RSN IE
Automatic auth_alg selection: 0x1
RSN: PMKSA cache search - network_ctx=(nil) try_opportunistic=1
RSN: Search for BSSID OO:OO:OO:OO:OO:OO
RSN: Consider OO:OO:OO:OO:OO:OO for OKC
RSN: No PMKSA cache entry found
RSN: using IEEE 802.11i/D9.0
WPA: Selected cipher suites: group 8 pairwise 8 key_mgmt 2 proto 2
WPA: clearing AP WPA IE
WPA: set AP RSN IE - hexdump(len=22): 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab
WPA: using GTK TKIP
WPA: using PTK TKIP
WPA: using KEY_MGMT WPA-PSK
WPA: not using MGMT group cipher
WPA: Set own WPA IE default - hexdump(len=22): 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab
No keys have been configured - skip key clearing
State: SCANNING -> ASSOCIATING
wpa_driver_wext_set_operstate: operstatioctl[SIOCSIWFREQ]: Device or resource busy
e 0->0 (DORMANT)
netlink: Operstate: linkmode=-1, operstate=5
wpa_driver_wext_associate
wpa_driver_wext_set_drop_unencrypted
wpa_driver_wext_set_psk
Association request to the driver failed
Setting authentication timeout: 10 sec 0 usec
EAPOL: External notification - EAP success=0
EAPOL: External notification - EAP fail=0
EAPOL: External notification - portControl=Auto
Wireless event: cmd=0x8b1a len=20
RTM_NEWLINK: operstate=0 ifi_flags=0x11003 ([UP][LOWER_UP])
Wireless event: cmd=0x8c08 len=24
AssocResp IE wireless event - hexdump(len=16): 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef
Wireless event: cmd=0x8b15 len=20
Wireless event: new AP: OO:OO:OO:OO:OO:OO
Association info event
resp_ies - hexdump(len=16): 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef
State: ASSOCIATING -> ASSOCIATED
wpa_driver_wext_set_operstate: operstate 0->0 (DORMANT)
Associated to a new BSS: BSSID=OO:OO:OO:OO:OO:OO
Associated with OO:OO:OO:OO:OO:OO
WPA: Association event - clear replay counter
RSN: PMKSA cache search - network_ctx=0x9c8e950 try_opportunistic=0
WPA: Clear old PTK
EAPOL: External notification - portEnabled=0
EAPOL: External notification - portValid=0
EAPOL: External notification - portEnabled=1
EAPOL: SUPP_PAE entering state CONNECTING
EAPOL: SUPP_BE entering state IDLE
RX EAPOL from OO:OO:OO:OO:OO:OO
RX EAPOL - hexdump(len=99): 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
IEEE 802.1X RX: version=1 type=3 length=95
  EAPOL-Key type=2
  key_info 0x89 (ver=1 keyidx=0 rsvd=0 Pairwise Ack)
  key_length=32 key_data_length=0
  replay_counter - hexdump(len=8): 00 00 00 00 00 00 00 01
  key_nonce - hexdump(len=32): 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef
  key_iv - hexdump(len=16): 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  key_rsc - hexdump(len=8): 00 00 00 00 00 00 00 00
  key_id (reserved) - hexdump(len=8): 00 00 00 00 00 00 00 00
  key_mic - hexdump(len=16): 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
WPA: RX EAPOL-Key - hexdump(len=99): 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
State: ASSOCIATED -> 4WAY_HANDSHAKE
WPA: RX message 1 of 4-Way Handshake from OO:OO:OO:OO:OO:OO (ver=1)
RSN: msg 1/4 key data - hexdump(len=0):
WPA: Renewed SNonce - hexdump(len=32): 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef
WPA: PTK derivation - A1=mm:mm:mm:mm:mm:mm A2=OO:OO:OO:OO:OO:OO
WPA: PMK - hexdump(len=32): [REMOVED]
WPA: PTK - hexdump(len=64): [REMOVED]
WPA: WPA IE for msg 2/4 - hexdump(len=22): 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab
WPA: Sending EAPOL-Key 2/4
WPA: TX EAPOL-Key - hexdump(len=121): 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 00 00 00 00 00 00 00 00
RX EAPOL - hexdump(len=161): 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 00 00 00 00 00 00 00 00 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef
IEEE 802.1X RX: version=1 type=3 length=157
  EAPOL-Key type=2
  key_info 0x13c9 (ver=1 keyidx=0 rsvd=0 Pairwise Install Ack MIC Secure Encr)
  key_length=32 key_data_length=62
  replay_counter - hexdump(len=8): 00 00 00 00 00 00 00 02
  key_iv - hexdump(len=16): 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef
  key_mic - hexdump(len=16): 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef
WPA: RX EAPOL-Key - hexdump(len=161): 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 00 00 00 00 00 00 00 00 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef
RSN: encrypted key data - hexdump(len=62): 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab
WPA: decrypted EAPOL-Key key data - hexdump(len=62): [REMOVED]
State: 4WAY_HANDSHAKE -> 4WAY_HANDSHAKE
WPA: RX message 3 of 4-Way Handshake from OO:OO:OO:OO:OO:OO (ver=1)
WPA: IE KeyData - hexdump(len=62): 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab
WPA: RSN IE in EAPOL-Key - hexdump(len=22): 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab
WPA: GTK in EAPOL-Key - hexdump(len=40): [REMOVED]
WPA: Sending EAPOL-Key 4/4
WPA: TX EAPOL-Key - hexdump(len=99): 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 01 23 45 67 89 ab cd ef 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
WPA: Installing PTK to the driver.
wpa_driver_wext_set_key: alg=2 key_idx=0 set_tx=1 seq_len=6 key_len=32
EAPOL: External notification - portValid=1
State: 4WAY_HANDSHAKE -> GROUP_HANDSHAKE
RSN: received GTK in pairwise handshake - hexdump(len=34): [REMOVED]
WPA: Group Key - hexdump(len=32): [REMOVED]
WPA: Installing GTK to the driver (keyidx=1 tx=0 len=32).
WPA: RSC - hexdump(len=6): 00 00 00 00 00 00
wpa_driver_wext_set_key: alg=2 key_idx=1 set_tx=0 seq_len=6 key_len=32
WPA: Key negotiation completed with OO:OO:OO:O:OO:OO [PTK=TKIP GTK=TKIP]
Cancelling authentication timeout
State: GROUP_HANDSHAKE -> COMPLETED
CTRL-EVENT-CONNECTED - Connection to OO:OO:OO:OO:OO:OO completed (auth) [id=0 id_str=]
wpa_driver_wext_set_operstate: operstate 0->1 (UP)
netlink: Operstate: linkmode=-1, operstate=6
EAPOL: External notification - EAP success=1
EAPOL: SUPP_PAE entering state AUTHENTICATING
EAPOL: SUPP_BE entering state SUCCESS
EAPOL: SUPP_PAE entering state AUTHENTICATED
EAPOL: Supplicant port status: Authorized
EAPOL authentication completed successfully
RTM_NEWLINK: operstate=1 ifi_flags=0x11043 ([UP][RUNNING][LOWER_UP])
EAPOL: startWhen --> 0
EAPOL: disable timer tick
CTRL-EVENT-TERMINATING - signal 2 received
Removing interface wlan0
wpa_driver_wext_deauthenticate
State: COMPLETED -> DISCONNECTED
wpa_driver_wext_set_operstate: operstate 1->0 (DORMANT)
BSS: Remove id 0 BSSID OO:OO:OO:OO:OO:OO SSID 'MYESSID12345'
netlink: Operstate: linkmode=0, operstate=6
after the last command, wlan0 goes DOWN and I have to make it up using sudo iwconfig wlan0 up command again. Also I tried removing network-manager package based on a comment saying this may solve the problem, but no success.
Also tried to edit wpa_supplicant.conf1 file as follows:
TRY #1 for wpa_supplicant.conf
network={
    ssid="MYESSID12345"
    #psk="MYPASSWORD$1234567"
TRY #2 for wpa_supplicant.conf
network={
    ssid="MYESSID12345"
    scan_ssid=1
    key_mgmt=WPA-PSK
    proto=RSN WPA
    pairwise=CCMP TKIP
    group=CCMP TKIP
PHP Learner
  • 2,948
First of all, I think you'll have better luck if your router is set to use WPA2-AES and not TKIP.
Second, I believe you are taking the long, complicated route when the short, easy route would work perfectly well. First, I suggest you back up your current wpa_supplicant.conf file:
sudo mv /etc/wpa_supplicant/wpa_supplicant.conf  /etc/wpa_supplicant/wpa_supplicant.bak
Next, I suggest you edit /etc/network/interfaces:
auto lo
iface lo inet loopback
auto wlan0
iface wlan0 inet static
address 192.168.1.150
netmask 255.255.255.0
gateway 192.168.1.1
wpa-essid MYESSID12345
wpa-psk MYPASSWORD$1234567
Of course, substitute your details here. Restart the interface:
sudo ifdown wlan0 && sudo ifup -v wlan0
Test:
ping -c3 www.ubuntu.com
If you get ping results, you are connected.
chili555
  • 61,330
I ran into this today as well. I pulled out a wpa_supplicant.conf file that has worked for me in the past on my Raspberry Pi devices and used it here. Once I tried with this file, my wpa_supplicant was consistently connecting.
I took some time today to try and disable some of the network= sections to try and narrow down which one section was applicable for my wireless network, but I gave up after a while. Taking out and putting back individual sections seemed to be narrowing things down, but then I don't know why it still wasn't connecting, so I gave up and put the whole thing back in there and got myself a DHCP IP address from my router.
Here was the /etc/wpa_supplicant/wpa_supplicant.conf file I used:
network={
    ssid="MYESSID12345"
    scan_ssid=1
    proto=RSN
    key_mgmt=WPA-PSK
    pairwise=CCMP
    auth_alg=OPEN
    priority=999
network={ ssid="MYESSID12345" psk="MYPASSWORD$1234567" proto=RSN key_mgmt=WPA-PSK pairwise=CCMP auth_alg=OPEN priority=99 }
network={ ssid="MYESSID12345" scan_ssid=1 key_mgmt=NONE priority=2 }
network={ ssid="MYESSID12345" psk="MYPASSWORD$1234567" proto=RSN key_mgmt=WPA-PSK pairwise=CCMP auth_alg=OPEN priority=-1 }
With this, I ran:
$ sudo -i
# cd /etc/wpa_supplicant
# wpa_supplicant -Dwext -i wlp1s0 -c wpa_supplicant.conf
Successfully initialized wpa_supplicant
wlp1s0: CTRL-EVENT-CONNECTED - Connection to ... completed [id=0 id_str=]
I still got the same errors in stdout, but things still looked better and more info in /var/log/syslog than before.
After this in a separate console:
# dhclient -v -r wlp1s0
# dhclient -v wlp1s0
I got my IP address and so I was able to proceed:
$ ping 8.8.8.8
jia103
  • 151
