I am fairly new to Ubuntu, so I hope someone can help to solve this problem or guide me to get in the right direction.
I have installed Ubuntu version 14.04 LTS on a new AMD A4-5000 APU. The OS is running on a Kingston V300 120Gb SSD. The OS is running fine.
I have installed a second HDD drive after I finished the initial Ubuntu installation. This disc is a 750 Gb former (windows) laptop HDD. I have deleted the partition first, re-partitioned it and formatted it with EXT4. At first everything seems to work fine. Within Ubuntu you can see and do everything with the disc as expected.
But the strange thing comes after starting a application, for example Kodi. When you browse to the disc, the disc is not recognized. I have all my media located at the disc, so I can not access it. I found out that when I access the disc physically first in Ubuntu before starting Kodi, it recognize the disc and you can use it as normal.
Now my question is, what seems to be the problem and how can I solve this?
Thanks,
Robert
RobertH
Looks like your disk is not mounted at boot, so you must click it in Ubuntu first to mount it before it will show in any applications.
You will need some information for it to auto-mount, first the name of the disk ie dev/sda or dev/sdb and also a location to mount the disk (I will use your home folder for this example,system default is /media)
First back up then open this file
sudo cp /etc/fstab /home/youruserhere
Editing for your users /home, then
gksu gedit /etc/fstab
Be careful with this file as it can quite easily cause you system to not boot.
Now we will add the disk to the file so it auto mount, at the bottom of the page add this
#device        mountpoint             fstype    options  dump   fsck
/dev/sd?    /home/yourname/mydisk    ext4    defaults    0    1
Edit the line device to match your disks name and edit the mount point to your liking, then save and reboot and your disk should be mounted at boot.
Thanks to @msys for his answer, please give him a upvote if this works for you.
Mark Kirby
  • 18,949
  • 19
  • 79
  • 116
