I was trying to change default boot option for my laptop(ubuntu and Windows). I can not update the grub which is the last step. When enter the command "sudo update-grub" i get this error "Searching for GRUB installation directory ... found: /boot/grub /etc/default/grub: line 1: ^Y: command not found".
I followed these instructions, How do I set Windows to boot as the default in the boot loader?
I installed boot-repair tool and this is my URL: http://paste.ubuntu.com/11907417/
algOs
Your /etc/default/grub has a stray ^Y in it:
=================== /etc/default/grub :
^Y
If you change this file, run 'update-grub' afterwards to update
/boot/grub/grub.cfg.
For full documentation of the options in this file, see:
info -f grub -n 'Simple configuration'
Just delete that line and you should be fine. You can use the following command to delete line 1 (since that's where the error is):
sed -i.bak 1d /etc/default/grub
muru
  • 207,228
