How can I install Turbo C or Code::Blocks on Ubuntu? I am new to Ubuntu so please explain step-by-step.
I tried to write a program in Gedit, but could not find out how to run and execute it.
TRiG
  • 2,006
Code::Blocks
Just open the Ubuntu Software Center and search for its name.
Or install via the terminal:
sudo apt-get install codeblocks
Source : How to install the Code::Blocks IDE?
To run Turbo C++ in Ubuntu you must have the following:
A.Turbo C++ setup If you have the setup then excellent
B.DOSBox Emulator If you have it installed on your system the good but if you don't go to Ubuntu Software Center and search for DOSBox and install the emulator.
or using terminal:
sudo apt-get install dosbox
Now follow these steps...
1.Extract the rar file and you'll get a setup folder.
If you don't have unrar utility you just need to install small package called " unrar "
Step 1 : goto your Terminal then type
sudo apt-get install unrar
you can now extract your .RAR file by "right-click" then chose " extract here "
or via terminal
 unrar dosbox.rar
Move the extracted folder to your home folder
2.Open the DOSBox emulator
Write the following commands :
   1.mount c ~
   2.C:
   3.cd setup
   4.install.exe
3.The turbo C++ installation utility will appear.Press Enter.
Enter the source drive as C.Press Enter.
Change the source path to \setup if it isn't.Press Enter.
4.Select Start Installation and Press Enter.
The installer will install the files.Once finished u can delete the setup folder.
5.To run the Turbo C++ every time run the following commands:
 1.mount c ~
   2.C:
   3.cd tc\bin
   4.tc.exe
To enter into fullscreen mode press Alt+Enter and press it again for window mode.
Sources: http://bharatflake.blogspot.com/2012/07/how-to-instal-turbo-c-in-ubuntu.html How do I install turbo c++?
Jeffrey M
  • 116
