I'm building a debian package from the source code. The package has, among the others, the following dependency (part of debian/control):
libswarm-dev (>= 0.6.1.0), libswarm-dev (<< 0.7),
This package and the project I'm trying to build are related to Yandex.Cocaine platform and Reverbrain company, which are not well-known, but I suspect that my problem is more general and not related to the specific package. So, there are a lot of suitable versions of it in the connected repo:
vagrant@worker-2:~/cocaine/cocaine-plugins$ apt-cache policy libswarm-dev
libswarm-dev:
  Installed: (none)
  Candidate: 0.8.1.0
  Version table:
     0.8.1.0 0
        500 http://repo.reverbrain.com/trusty/ current/amd64/ Packages
     0.8.0.0 0
     0.7.3.0 0
     0.7.2.0 0
     0.7.1.0 0
     0.7.0.11 0
     0.7.0.10 0
     0.7.0.9 0
     0.7.0.8 0
     0.7.0.7 0
     0.7.0.6 0
     0.7.0.5 0
     0.7.0.4 0
     0.7.0.3 0
     0.7.0.2 0
     0.7.0.1 0
     0.6.5.1 0
     0.6.5.0 0
     0.6.3.9 0
     0.6.3.8 0
     0.6.3.7 0
     0.6.3.6 0
     0.6.3.5 0
     0.6.3.4 0
     0.6.3.3 0
     0.6.3.2 0
     0.6.3.1 0
     0.6.3.0 0
However, for some reason apt-get doesn't want to install them. Instead, apt insists on the latest version:
vagrant@worker-2:~/cocaine/cocaine-plugins$ sudo apt-get install libswarm-dev=0.6.5.1
Reading package lists... Done
Building dependency tree
 libswarm-dev : Depends: libswarm2 (= 0.6.5.1) but 0.8.1.0 is to be installed
                Depends: libswarm2-urlfetcher (= 0.6.5.1) but 0.8.1.0 is to be installed
                Depends: libswarm2-xml (= 0.6.5.1) but 0.8.1.0 is to be installed
apt-get install -f doesn't help too:
vagrant@worker-2:~/cocaine/cocaine-plugins$ sudo apt-get install -f
0 upgraded, 0 newly installed, 0 to remove and 41 not upgraded.
All the dependencies of the libswarm-dev package have the required versions:
vagrant@worker-2:~$ apt-cache policy libswarm2
libswarm2:
  Installed: (none)
  Candidate: 0.8.1.0
  Version table:
     0.8.1.0 0
     0.6.5.1 0
vagrant@worker-2:~$ apt-cache policy libswarm2-urlfetcher
libswarm2-urlfetcher:
  Installed: (none)
  Candidate: 0.8.1.0
  Version table:
     0.8.1.0 0
     0.6.5.1 0
vagrant@worker-2:~$ apt-cache policy libswarm2-xml
libswarm2-xml:
  Installed: (none)
  Candidate: 0.8.1.0
  Version table:
     0.8.1.0 0
     0.6.5.1 0
Of course I can install each of them by hand (and I eventually did), but obviously it is not a right way. I think it is work of apt, not mine. How can I resolve this?
This is Trusty release of Ubuntu.
ars
  • 151
Have you tried the steps here?
If not quick recap:
  • Make sure universe and restricted repositories enabled. Hit Alt+F2, type software-properties-gtk and hit Enter.
  • Run sudo apt-get update This updates your package index files.
  • Run sudo apt-get clean. This clears out the local repository of retrieved package files (the .deb files).
  • Run sudo apt-get -f install. This will correct broken dependencies.
  • Run sudo dpkg --configure -a
  • Run sudo apt-get -f install again.
dzil123
  • 62
