I want to remove and purge apache2 - Why does this trigger an install of php5-cgi ?
sudo apt-get --purge remove apache2
Reading package lists... Done Building dependency tree
Reading state information... Done The following packages were automatically installed and are no longer required: linux-headers-3.19.0-20 linux-headers-3.19.0-20-generic linux-image-3.19.0-20-generic linux-image-extra-3.19.0-20-generic linux-signed-image-3.19.0-20-generic linux-tools-3.19.0-20 linux-tools-3.19.0-20-generic Use 'apt-get autoremove' to remove them. The following extra packages will be installed: php5-cgi Suggested packages: php-pear The following packages will be REMOVED: apache2* libapache2-mod-php5* The following NEW packages will be installed: php5-cgi 0 upgraded, 1 newly installed, 2 to remove and 15 not upgraded. Need to get 4,419 kB of archives. After this operation, 8,152 kB of additional disk space will be used. Do you want to continue? [Y/n] n Abort.
When I issued above, it did in fact install that new package! I would not think it's an alternative
The package php5 depends on having either apache2 or cgi installed.
The two main options to satisfy this dependency is either libapache2-mod-php5 or php5-cgi.
If you remove one, the system will install the other, otherwise php5 would have an unmet dependency.
You can see the dependencies at php5 in the Ubuntu packages database.
chaskes
  • 15,536
