unattended-upgrade recently automatically upgrade my kernel to 4.4.0-143 but it does not work with Nvidia graphic cards so I decided to roll back to previous version.
I am able to boot to an older kernel(4.4.0-141), and confirmed I'm booting my computer with that:
4.4.0-141-generic
but when I tried to apt purge linux-image-4.4.0-143-generic, apt prompts me to confirm:
The following NEW packages will be installed:
  linux-image-unsigned-4.4.0-143-generic
So why is uninstalling a signed kernel requires to install an unsigned version? And how can I safely remove the newer(143) kernel? Thanks in advance!
full output of apt purge:
Reading package lists... Done
Building dependency tree
The following packages were automatically installed and are no longer required:
  amd64-microcode intel-microcode iucode-tool linux-headers-4.4.0-137 linux-headers-4.4.0-137-generic linux-headers-4.4.0-138 linux-headers-4.4.0-138-generic linux-headers-4.4.0-139 linux-headers-4.4.0-139-generic linux-headers-4.4.0-141 linux-headers-4.4.0-141-generic
  linux-image-4.4.0-137-generic linux-image-4.4.0-138-generic linux-image-4.4.0-139-generic linux-image-4.4.0-141-generic linux-image-extra-4.4.0-137-generic linux-image-extra-4.4.0-138-generic linux-image-extra-4.4.0-139-generic linux-image-extra-4.4.0-141-generic
  linux-signed-image-4.4.0-137-generic linux-signed-image-4.4.0-138-generic linux-signed-image-4.4.0-139-generic linux-signed-image-4.4.0-141-generic thermald
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
Suggested packages:
  fdutils linux-doc-4.4.0 | linux-source-4.4.0 linux-tools
The following packages will be REMOVED:
  linux-generic* linux-image-4.4.0-143-generic* linux-image-generic* linux-signed-generic*
0 upgraded, 1 newly installed, 4 to remove and 140 not upgraded.
Need to get 7,049 kB of archives.
After this operation, 386 kB of additional disk space will be used.
Do you want to continue? [Y/n] n
imkzh
  • 121
I’ve found the answer myself with the hints from deleted answer by @mikewhatever. (see him in comments, https://askubuntu.com/users/20054/mikewhatever)
The reason is some package is depending on either linux-image-4.4.0-143-generic or linux-image-unsigned-4.4.0-143-generic. So simply purging the signed kernel will trigger an automatic installation of the unsigned one to satisfy the dependency.
So I checked the reverse dependency of linux-image-4.4.0-143-generic
# apt-cache rdepends linux-image-4.4.0-143-generic
Reverse Depends:
 |linux-image-generic
 |linux-modules-extra-4.4.0-143-generic
 |linux-image-virtual
And purged all of those reported. Then I am able to purge linux-image-4.4.0-143-generic painlessly.
see: apt-get -- remove triggers a package install?
thyu
  • 477
imkzh
  • 121
