I have a number of Windows based .m3u playlists - they start with ..\..\ and have \ instead of / for folder paths, whereas Ubuntu prefers they start with /media/usr/part/dir/ (i.e. the absolute path).
I want to make the following changes
  1. Replace all ..\..\ with /media/usr/part/dir/
  2. Replace all \ with /
I tried using find /home/user/directory -name \*.m3u -exec sed -i "s/\.\.\\\.\.\/\/media\/usr\/part\/dir\//g" {} \; as suggested here, and tried using _ and : as delimiters as suggested here.
However, I keep getting
sed: -e expression #1, char 36: unterminated `s' command
How do I make the necessary replacements in my files?
3l4ng
  • 926
  • 26
This sed command is wrong, because it has a missing \ before the first /, which leads the preceding \ to escape it as a literal / (changing the pattern and "eating" the separator) and, for the purpose of replacing a single occurence of ..\..\ on each line, it has an excessive g switch at the end; in any case it's missing the replacement of the \ characters with the / character part.
Use this one instead; I've took the liberty of changing the separator to get rid of a likely sudden leaning toothpick syndrome and to change ; with + to improve the command's performance over a huge number of files:
find /home/user/directory -name \*.m3u -exec sed -i 's|\.\.\\\.\.\\|/media/usr/part/dir/|; s|\\|/|g' {} \+
Output:
~/tmp$ cat playlist1.m3u
..\..\path1
stuff
..\..\path2\path2
stuff
..\..\path3\path3\path3
stuff
~/tmp$ find . -name \*.m3u -exec sed -i 's|\.\.\\\.\.\\|/media/usr/part/dir/|; s|\\|/|g' {} \+
/media/usr/part/dir/path1
stuff
/media/usr/part/dir/path2/path2
stuff
/media/usr/part/dir/path3/path3/path3
stuff
kos
  • 41,268
