I would like to unpack a .pak file on Ubuntu 14.04.
How should I proceed?
1. method
sudo apt-get install p7zip-full
https://apps.ubuntu.com/cat/applications/p7zip-full/
It should be capable of opening .pak files
2. method
Unrar (non-free) from Software Center, where multiverse repos must be enabled!How do I enable the "multiverse" repository?
https://launchpad.net/ubuntu/+source/unrar-nonfree
3. method
Install WinRAR via Wine
http://www.rarlab.com/download.htm
http://www.howtogeek.com/105271/how-to-run-windows-software-on-ubuntu-with-wine/
4. method (overkill)
IF IT IS A GAME FILE: Many games have their own extractor. Unless you know exactly what program made it, AND you can find the proper extractor, AND you have all the files (if split) you're out of luck.
This is a long-dead thread, but here is some information that may be of help if anyone should need to work with PAK files:
I tried p7zip but it does not recognize the .PAK file extension (even in lower case.)
/usr/bin/p7zip: SONGS.PAK: unknown suffix -- ignored
There was a program called PAKF.EXE that was copyrighted 1988 by NoGate Consulting which supported the PAK file extension. It ran in Windows. I ran it today in DOSBox on my Ubuntu 14.04 machine (but my copy is copyrighted so I should not share it.)
This site [ https://www.sac.sk/files.php?d=7&l=P ] lists several compression tools, including pak251.exe by NoGate Consulting. The exe is downloadable and there are many other compression tools in the list as well.
The definitive approach to extracting .PAK from Quake and Quake II or similar games is this little utility called qunpak: https://indigo.re/qunpak/.
You just download the file, chmod +x it and if you plan on using it again, either sudo mv it to /usr/local/bin or just mv it to ~/.local/bin. That's going to add it to PATH so you would be able to use it as any other command.
Then just qunpak -x the file in question. If unsure, consult qunpak --help or the README.md
