11
So I tried to start my apache2 server with the following command...
sudo service apache2 start
But then I get this error message...
Job for apache2.service failed. See "systemctl status apache2.service" and "journalctl -xe" for details.
So when I try and see the systemctl, I get this...
● apache2.service - LSB: Apache2 web server
   Loaded: loaded (/etc/init.d/apache2)
   Active: failed (Result: exit-code) since Mon 2015-07-06 10:34:49 IST; 4min 23s ago
     Docs: man:systemd-sysv-generator(8)
  Process: 8899 ExecStart=/etc/init.d/apache2 start (code=exited, status=2)
Jul 06 10:34:49 archisman-HP-ProBook-440-G2 systemd[1]: Starting LSB: Apache2 web server...
Jul 06 10:34:49 archisman-HP-ProBook-440-G2 apache2[8899]: /etc/init.d/apache2: 64: .: Can't open /etc/apache2/envvars
Jul 06 10:34:49 archisman-HP-ProBook-440-G2 apache2[8899]: /etc/init.d/apache2: 76: .: Can't open /etc/apache2/envvars
Jul 06 10:34:49 archisman-HP-ProBook-440-G2 apache2[8899]: ERROR: APACHE_PID_FILE needs to be defined in /etc/apache2/envvars
Jul 06 10:34:49 archisman-HP-ProBook-440-G2 systemd[1]: apache2.service: control process exited, code=exited status=2
Jul 06 10:34:49 archisman-HP-ProBook-440-G2 systemd[1]: Failed to start LSB: Apache2 web server.
Jul 06 10:34:49 archisman-HP-ProBook-440-G2 systemd[1]: Unit apache2.service entered failed state.
Jul 06 10:34:49 archisman-HP-ProBook-440-G2 systemd[1]: apache2.service failed.
http://localhost/ on my browser also gives me an error which means apache is not running.
When I do this...
sudo restart apache2
I get this error...
restart: Unable to connect to Upstart: Failed to connect to socket /com/ubuntu/upstart: Connection refused
Somebody please help.
I think for some reason you deleted envvars config file
So you have to create it and paste the content from here (default content for this file)
sudo touch /etc/apache2/envvars
sudo nano /etc/apache2/envvars
Then restart apache service as usual
sudo service apache2 restart
bistoco
  • 1,541
I had the same problem, I made changes in apache.conf file for some reason, which leads me to the same error as you.
I have reinstalled Apache server, now everything is working fine.
Use the following commands:
  1. Uninstall Apache:
     sudo apt-get remove apache2*
  2. Install Apache
     sudo apt-get install apache2
  3. Restart server
  4. If you see an error "no listening sockets available, shutting down" please change port to 8080 or different ports under /etc/apache2/ports.conf file, this might be due to TCP port 80 being already in use by another program.
