I have been playing around with ffserver, and ffmpeg to set a real time stream with my webcam. I once (actually 4-5 times) got it to work but now every time I try to launch the server I got this error: Missing Audio stream which is needed for this ffm.
Here is how I launch it:
ffserver -f ffserver.conf & ffmpeg -i /dev/video0 http://localhost:8090/feed1.ffm
I tried to modify many things in the ffserver.conf file such as different video format /codec putting the line NoAudio removing it etc... I even try, with a video file containing audio instead of the camera, it doesnt change anything... I can't got it to work any more.
I am quite desperate, because I searched the web for an answer, but didn't find anything... I hope some people here can help or at least submit ideas or thoughts, at this point I am taking anything!
Fabby
  • 35,017
victor jung
  • 81
so I found the solution myself! So you have to add NoAudio in the block to be sure, it's mandatory or not depending on the format you use. The thing is if you tried to launch ffserver and it doesnt work, due to some mistakes in the ffserver.conf files, it's not enough to correct them, you need to close the shell where you tried to launch it, re-open a new shell and retry, otherwise the error happens again for some ultra weird reasons.
Same for all the errors, you have to correct your ffserver.conf, close the shell where you tried to launch it, and open a new one to try to start the server again.
Hope this can help few of you.
victor jung
  • 81
In my case, the problem was that I was using the default ffserver.conf (as found in the doc directory of the source distribution and in /etc/ffserver.conf of the Ubuntu FFmpeg package). The default ffserver.conf has two different <Stream> blocks blocks that use feed1.ffm, and I hadn't realized this, so even though I marked the first stream block as NoAudio, the second stream block was still requiring it.
Switching to a minimal ffserver.conf containing only the blocks and directives I needed fixed this.
You don't need to kill the shell itself (bash, most likely) but just the ffserver process, then restart it. This usually amounts to just using (in that shell window) Control-C, Up-Arrow (or Control-P), and return.
I'm running my ffmpeg from inside of the /etc/ffserver.conf file using Launch (in a Feed section), so restarting ffserver does everything. A basic Launch line might look like:
Launch ffmpeg -r 5 -i /dev/video0
To see if you have any strays running, use this (rather casual command) in a second window: ps -ef | grep ff
