I am trying to install Chrome on my system but instead of installing it says 'reinstall' and never actually opens or loads. This is also the case when I try to install Flash Player - I can see the file in software centre but it doesn't actually install.
Sorry I am very new to Ubuntu.
My laptop has the following processor:
Intel® Pentium(R) M processor 1.70GHz
748.3mb RAM
Thank you
Maythux
  • 87,123
Dorothy
  • 71
To install google chrome Either download from PPA or using .deb
PPA
Using terminal. run those commands, you can open termianl by searching from dash or keyboard shortcut CTRL+Alt+t
wget -q -O - https://dl-ssl.google.com/linux/linux_signing_key.pub | sudo apt-key add -
sudo sh -c 'echo "deb [arch=amd64] http://dl.google.com/linux/chrome/deb/ stable main" >> /etc/apt/sources.list.d/google.list'
sudo apt-get update
sudo apt-get install google-chrome-stable
using .deb
wget https://dl.google.com/linux/direct/google-chrome-stable_current_amd64.deb
sudo dpkg –i google-chrome-stable_current_amd64.deb
Jibbers
  • 562
Maythux
  • 87,123
How are you trying to install it? I recommend running this command from a terminal:
Try and totally remove chrome using the following code
sudo apt-get --purge remove google-chrome-stable
You also need to delete or rename /home/your_name/.config/google-chrome (.config is hidden. You'll need to press ctrl+H to see it)
then finally run this in your terminal to install chrome, as found on the following link
if [[ $(getconf LONG_BIT) = "64" ]]
then
    echo "64bit Detected" &&
    echo "Installing Google Chrome" &&
    wget https://dl.google.com/linux/direct/google-chrome-stable_current_amd64.deb &&
    sudo dpkg -i google-chrome-stable_current_amd64.deb &&
    rm -f google-chrome-stable_current_amd64.deb
else
    echo "32bit Detected" &&
    wget https://dl.google.com/linux/direct/google-chrome-stable_current_i386.deb &&
    sudo dpkg -i google-chrome-stable_current_i386.deb &&
    rm -f google-chrome-stable_current_i386.deb
fi
GO to google chrome site and download, save file in downloads. Do not let it open in software center yet. GO to downloads and right click on the chrome downloaded file and select let program run as install (Executable) . Close that and double click the file, should open software center and install.
Tom C
