Usually before I load into an OS, I get the option menu to select Windows 7 or Recovery mode(I have thinkpadx220);
Then I used Unetbootin, which appeared as the third option. After installing Ubuntu 15.04, I don't see this option anymore it just goes straight into Ubuntu without the option for Win7, Recovery, or even Unetbootin.
I can still view all my files from Ubuntu though like Program Files and Windows folders.
I already tried this https://help.ubuntu.com/community/Boot-Repair
I made my log at https://paste.ubuntu.com/11791943/
It didn't fix it.
I think the grub is creating issues. Reinstall grub.
Try this:
Edit the GRUB Configuration File, open the /etc/default/grub file for editing in a standard text editor.
If you want to use a graphical text editor, open a terminal — or press Alt+F2 — and run the following command:
gksu gedit /etc/default/grub
psyCHOder
  • 494
Insert the Bootable Drive of Windows 7(Of the same Version of Your Windows 7 You Are using) And Repair The PC
Anonymous
  • 111
