I did a normal install of Ubuntu 12.04 using the Alt ISO. When I try to install ltsp-server-standalone I get:
ltsp@ubuntu32:~$ sudo apt-get install ltsp-server-standalone
Reading package lists... Done
Building dependency tree
ltsp-server-standalone :
Depends: ldm-server but it is not going to be installed
Depends: ltsp-server but it is not going to be installed
Depends: ltspfs but it is not installable
Depends: nbd-server (>= 1:2.9.25-2) but it is not installable
Recommends: isc-dhcp-server but it is not going to be installed
Recommends: pulseaudio-esound-compat but it is not going to be installed
I would like to use 12.04 because alot of the ltsp guides are based on it.
